HB TCXX电房
12-8-19 00:16| 发布者: rcfans| 查看: 7510| 评论: 5
HB(Hot Bodies)正式推出TCXX 1/10电动房车。世界冠军车手Atsushi Hara在上月刚刚结束的IFMAR世界赛上使用该车夺得TQ和世界亚军。TCXX新车使用一块2.5mm厚度的超窄身底板,除了提高弯道性能外同时能有效防止底板侧边摩擦路面。电池的摆放位置更接近车架中线,马达的位置能够有效抵消现在流行的轻量化舵机、接收机和电子变速器带来的车架重量分布不平均问题。 新设计的铝制舵机座支持矮身舵机和标准舵机,原车提供1.2mm, 1.3mm和1.4mm防倾杆。避震和悬挂也使用了新组件,提供更多可调选择。  欢迎进入HPI品牌专区参与讨论
新特性:
  • Optimized design and balance for modern LiPo batteries
  • New narrow 2.5mm thick chassis
  • New carbon battery mount
  • New one-piece symmetrical 2.5mm top deck
  • Compact bulkheads
  • Split pivot blocks for more chassis flex
  • New compact motor mount
  • New aluminum spur gear mount
  • Narrow layshaft and 20T pulleys
  • ‘Flipped’ belt drivetrain layout
  • Twin crank steering with new longer aluminum arms
  • New carbon steering tower bar
  • New steering arm post
  • New aluminum servo mount
  • Bulkheads fully symmetrical front to rear and left to right
  • Adjustable top deck flex with bulkhead screws
  • Motor mount completely under top deck
  • Servo and radio gear sit as close as possible to centerline
  • 20T layshaft pulleys and 39T front/rear pulleys combine for increased efficiency
  • Rear gear differential for less maintenance
  • Aluminum/steel front spool with aluminum sleeves
  • Aluminum & steel driveshafts
  • Lightweight steel axles with 2mm pins for cup joints
  • Clamping hex hubs
  • 3.65mm shock towers, 7 fine-pitch adjustment holes in front, 8 in rear
  • New aluminum shock stand-offs
  • Worlds-winning suspension design with longer top links
  • Reversible lower arms for extra shock positions
  • Adjustable anti-squat, toe, roll centre
  • Droop screws
  • Full set of turnbuckles
  • Threaded shock bodies with single o-ring construction
  • New aluminum spring adjuster and spring retainer
  • PTFE 3-hole shocks and spacers
  • Wide sway bar rods
  • Complete set of sway bars included (1.2mm, 1.3mm, 1.4mm)
  • Infinitely adjustable ball stud sway bar mounts
  • Fully equipped with ball bearings
  • Wheels, tires and inserts not included
  • Also requires body and electronics
    引用 zhangzy 12-8-19 17:25
    稀饭稀饭
    引用 ACGFANS 12-8-19 16:49
    victor1997621: 世界赛参赛选手的车子的全车零件都是以不计成本的方式去生产的!我想带弯角的转向杯是因为荷兰的赛道每个弯道都有弧度吧。。。
    不计成本毛 商家又不是慈善家 能卖就有赚 说白了就是他要赚你那个塑胶转向杯的钱 因为你要升级...
    引用 ACGFANS 12-8-19 16:47
    小编不懂脑子的..不磨底盘就是磨电池跟马达 这都好拿来说的
    引用 victor1997621 12-8-19 13:40
    dicksweet: 转向杯为什么是这种,世界赛上明明是带弯转角的转向杯,唉!
    引用 dicksweet 12-8-19 04:06
    查看全部评论(5)
