Team Associated推出12mm大容量避震器,CNC工艺制造,强化铝制避震筒和避震顶盖。这款避震AE厂方车手已经进行了长期测试,适合原厂各类型的1/10越野车遥控车使用。包括 2012 Cactus Classic大赛和全美大赛上,这款避震都已经装备在冠军车架上。欢迎进入AE品牌专区参与讨论,->点击这里进入 ![](http://image.rcfans.com/portal/201209/17/123639hrh0rorlmrlh0b8z.jpg)
- 12mm hard anodized "Big Bore" threaded shock body
- Titanium Nitride (TiN) 3mm shock shaft with stronger M3 threads
- Black hard-anodized aluminum shock cap with bleeder screw
- 12mm two-hole piston (1.5mm, 1.6mm and 1.7mm)
- Shock shaft hat bushing guide ensures concentric shock shaft alignment
- Optimized seal gland fit for smooth and consistent performance
- Factory Team blue anodized aluminum seal gland cap
- Factory Team blue anodized aluminum shock collar
- Three spring cup heights (+0mm, +5mm, +9mm offset)
- Includes mounting hardware and spacers
- Springs sold separately
![NEW! 12mm NEW! 12mm](http://www.teamassociated.com/pictures/news/articles/984/91314_md.jpg)
784695 913141 |
#91314 |
12mm Shock Kit (B4, B44 front — all model versions) |
784695 913158 |
#91315 |
12mm Shock Kit (SC10, T4 front — all modelversions) |
784695 913165/td> |
#91316 |
12mm Shock Kit (B4, B44, rear — all model versions) |
784695 913172 |
#91317 |
12mm Shock Kit (SC10, T4, rear — all model versions) |
