Mugen MBX7
12-11-27 12:05| 发布者: rcfans| 查看: 8517| 评论: 5
日本无限精机(Mugen Seiki)推出MBX7 1/8竞赛级油动越野车!MBX7设计团队力求提高车子的弯道速度、增加抓地力、降低重心和全面减轻传动部件重量。全新前悬挂摇臂让车子可以更高的速度入弯,尾悬挂除了增加抓地力外也让车子的跳跃过程更流畅。 轻量化传动组件全面提升车子的行走性能,15mm大容量避震器、全新刹车组件和新设计的油箱都出现在MBX7新车上,敬请期待!12月上市!
Features:
- 3mm A7075 hard anodised chassis
- Lightweight spur gear
- Lightweight conical gears
- Straight cut conical and ring gears
- Specialized designed front upper and lower suspension arm, front hub carriers, rear suspension arms and hub carriers.
- Fully adjustable steering with new geometry, servo saver and Ackermann plate.
- 15mm hard anodised threaded shocks with 3.5mm shock shaft and rubber shock boots
- 5mm A7075 aluminium front shock tower
- 4mm A7075 aluminium rear shock tower
- 5mm A7075 aluminium lower suspension mounts for optimised geometry
- Specialized brake system with new brake cam front/rear brakes, brake linkage and brake disc
- Small composite moulded receiver box & low centre of gravity battery holder
- Special designed fuel tank with an internal fuel clunk pick up
- E0710 heavy duty aluminium clutch shoes
- Stylish mid-cab body
- High down force wing which is adjustable front to back
    引用 入了mo界 12-11-29 22:16
    本来没有的  被你一说也有了不寒而栗的感觉
    引用 super_弟 12-11-27 22:33
    好车是要顶的~~~~~~~~~~~~~~~~~~~~~
    引用 自由大帝 12-11-27 22:27
    还是这种造型的壳好看~~~
    引用 长风大侠 12-11-27 15:00
    无限一直坚持的前球头后C座的设计,依然延续。
    引用 chenzhu33 12-11-27 14:44
    为什么我看邮箱盒子里面的那个有种不寒而栗的感觉。难道是由于有密集恐惧症?!
    查看全部评论(5)
