Associated Apex V-Type电房
12-12-9 15:49| 发布者: rcfans| 查看: 4937| 评论: 6
Team Associated推出The Qualifier系列入门产品,第一款产品Apex Touring Car是装备了Reedy无刷、4WD传动和Reedy WolfPack 6-cell电池的RTR 1:10电动房车。XP防水电子变速器,XP 2.4GHz遥控都包含在产品内。前后齿差,直轴传动,可调油压避震器、10副轮圈和定制的Team Lucas像真车壳都是产品标准配置。Team Assocaited将以Apex电房为起点,打开The Qualifier系列产品之门,将会陆续推出高性价比,耐用又富有乐趣的遥控车产品。
Features
  • Fully assembled Ready-To-Run shaft-drive 4WD Touring Car
  • Water-resistant XP SC500-BL brushless electronic speed control with Deans® Ultra Plug® (2S-3S LiPo compatible)
  • Powerful Reedy 3300kV 540 brushless motor
  • XP 2.4Ghz radio system with XP digital metal gear steering servo
  • Reedy WolfPack 6-cell NiMH battery with Deans® Ultra Plug® connector included
  • Composite modular chassis accepts NiMH or LiPo type batteries
  • Ten-spoke touring wheels with high-grip racing tires
  • Factory-finished authentic touring car body
  • Fluid filled adjustable shock absorbers
  • Steel CVA drive axles front and rear
  • Metric hardware and ball bearings throughout
  • Sealed metal gear differentials
    引用 jianglei222 12-12-11 13:38
    TT01
    引用 rave1010hk 12-12-10 12:50
    zhou61041194: 貌似是TT01?????好眼熟啊。。。。
    这是TC3的复刻,TC3这底盘已有十多年历史了。
    引用 zhou61041194 12-12-10 12:42
    引用 fppppp 12-12-10 02:28
    电放不应该是几片碳纤维加一堆金属件么? 本人只玩过电越,不了解
    引用 zb2759 12-12-10 02:15
    这。。。。TT01?
    引用 mayao11 12-12-9 22:18
    我这个只玩过短卡的觉得这个“房车”很业余,等楼下评价
    查看全部评论(6)
