Associated Qualifier系列ProLite 4×4短卡
12-10-24 10:38| 发布者: rcfans| 查看: 9075| 评论: 9
Team Associated推出全新的Qualifier级别产品线,该产品线属入门和中级产品,价格更低、更易入手和更耐用。ProLite 4X4短卡是第一款Qualifier产品线新车,出厂预装完成,RTR,配备Reedy无刷动力系统、4WD直轴传动、Reedy WolfPack电池(Deans接头)、Xp防水电子变速器、XP 2.4GHz遥控都是标准配置。密封式前后齿差、可调中差限滑也出现在这台新车上。相信ProLite短卡是一台性价比极高又具备良好性能的产品。 欢迎进入AE品牌专区参与讨论,->点击这里进入
Features
  • Fully assembled Ready-To-Run shaft drive 4WD short-course truck
  • Reedy 550-SL 3500kV Brushless motor
  • Reedy WolfPack 8.4V NiMH Battery with Deans® Ultra Plug® Connector
  • XP 2.4GHz radio system with XP metal-gear servo and enclosed receiver box
  • XP water-resistant LiPo-compatible electronic speed controller with Deans® Ultra Plug® connector
  • 12mm hex drive KMC(TM) replica wheels front and rear with aggressive short-course racing tires
  • Front CVAs and rear dogbones
  • Heavy-duty front and rear gear differentials
  • Durable 32-pitch spur gear with center slipper clutch
  • Adjustable steel turnbuckles
  • Fluid-filled shocks
  • Composite modular chassis
  • Rugged front and rear bumpers
  • Painted and decaled short-course body
  • All metric hardware and ball bearings throughout
http://cdn7.rccaraction.com/wp-content/gallery/team-associated-rtr-qualifier-series-prolite-4x4-short-course-truck/prolite_3q_body-off_2_md.jpg?8a12f1
Specifications:
Power Source: Electric
Terrain: Off-Road
Body Style: Truck
Scale Size: 1:10 Scale
Assembly Level: Ready-To-Run*
Length: 535mm (21.06in)
Width: 305mm (12.01in)
Wheelbase: 324mm (12.76in)
Weight: 2624g (5.78 lbs)
Drive: 4WD
http://cdn4.rccaraction.com/wp-content/gallery/team-associated-rtr-qualifier-series-prolite-4x4-short-course-truck/prolite_3q_body-off_md.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/team-associated-rtr-qualifier-series-prolite-4x4-short-course-truck/prolite_battery-holder_md.jpg?8a12f1
http://cdn6.rccaraction.com/wp-content/gallery/team-associated-rtr-qualifier-series-prolite-4x4-short-course-truck/prolite_blk_3q_md.jpg?8a12f1
12下一页
    引用 zwtnt168 12-10-26 12:44
    牛逼,我喜欢
    引用 foolsfools8 12-10-25 10:41
    车壳 和前防撞 忒难看了
    引用 super_弟 12-10-24 22:45
    丑。。。。。。。。。。。。。。。。。
    引用 lxh781107 12-10-24 18:13
    不是轴吧
    引用 sanshi_x 12-10-24 17:51
    这壳子太丑了。这是AE的东西吗~~~~~~~~~~~~~~~
    引用 武汉螃蟹 12-10-24 16:57
    AE的死老鼠?
    引用 马环宇 12-10-24 13:05
    轴传动啊
    引用 huafacheng 12-10-24 12:21
    皮帶傳動還是軸傳動啊?
    引用 RC高手 12-10-24 11:54
    更耐用和价格更低是否矛盾呢
    查看全部评论(9)
