Blade 550 X Pro系列直升机
12-12-14 23:07| 发布者: rcfans| 查看: 4956| 评论: 3
地平线模型(Horizon)宣布Blade 550 X Pro系列遥控直升机上市。550级电动机型,碳纤机体和无副翼(flybarless)系统。产品提供两个版本供玩家选择,kit和combo套装,其中combo套装包括130A电子变速器、1360kv无刷马达,10A BEC和550mm革命性CF主旋翼,搭配Spektrum AR7200BX DSMX FBL系统, Spektrum H6040舵机和H6080G陀螺仪。
点击->这里进入地平线品牌专区参与互动
Key Features
  • Direct-to-swash, flybarless head design
  • Carbon fiber main frames
  • CNC-machined aluminum head block
  • CNC-machined aluminum swashplate
  • Revolution® 550mm carbon fiber main blades
  • Triple ball bearing-supported, 10mm solid steel main shaft
  • Integrated bearing block servo mount design
  • Torque tube-driven tail with aluminum tail boom and case
  • Dual-point tail pitch slider and balanced tail grips
  • E-flite® 130A ESC
  • E-flite Heli 550, 1360Kv brushless outrunner motor
  • E-flite 10-Amp BEC
Product image
Product image
    引用 麻吕丸 12-12-15 11:44
    价格肯定也很漂亮
    引用 再说不见 12-12-15 09:31
    直机却是漂亮!!!!!!!!!!!
    引用 自由大帝 12-12-15 02:37
    喔~~~
    挺漂亮的~~~
