SAB Goblin 500电动直升机
13-1-8 01:43| 发布者: rcfans| 查看: 8706| 评论: 5
SAB Heli Division公布了他们即将推出的500级Goblin 500电动直升机。使用知名的Goblin设计组件,包括全碳纤机架和可快速拆装电池固定器。使用36mm cyclic舵机,52x52mm马达,最高支持6S 4500mAh电池。
http://www.goblin-helicopter.com/shop/imagesdesc/page1-500_1-2.jpg
General Specifications
Electronic Specifications
 Main rotor diameter:  1136mm (with 500 mm blades)
 HPS Head (FBL Only)
• Main blade length: 470 to 500mm
• Tail rotor diameter: 226 mm
• Tail blade length: 80 mm
• Main shaft diameter: 10 mm
• Tail shaft diameter: 5 mm
• Spindle shaft diameter: 8 mm
• Gear Ratios 6.9-11 : 1
• Weight including electronics: 1900 g (excluding flight battery).
18T motor pulley included (other pulley sizes available)
All pulleys are made for 6 mm motor shaft (5 mm motor shaft adapter included in kit)
Special Features:
• Full carbon fiber boom
• Quick release battery tray system
• Sacrificial breaking point for landing gear and boom
 Unique “inside the boom” tail push rod design
• Cyclic Servos: Mini size (36mm)
             Normal and 3D Flight: Hitec 5245 MG, Align DS510M or DS515M, Savox SH1250, Graupner DES 678 MG, MKS DS-9660A, Futaba 9650
              HARD 3D: Futaba BLS153, Graupner HBS660 HV, JR DS3717 HV, HITEC 7245 MG HV, JR DS3711 HV
• Tail Servo: Standard size (40mm)
• Typical Speed Controller: 80/100A
              Normal and 3D Flight: Kontronik Koby 90, YGE 100 LV
              HARD 3D: Kontronik Jive 100 LV, YGE 120 LV, CC Talon 90
• Motors: (Max Diameter: 52 mm, Max Height: 52 mm)
              Normal and 3D Flight: Scorpion HK-4015-1070, Quantum 4115-1200
              HARD 3D: PYRO 600-1200, Scorpion, HKIII-4020-1100/1350, Quantum 4120-1200
• Flight Battery: (Max Dimensions: 52x53x180mm)
              6S 2800/4500 mAh.
Kit Includes:
• 18T motor pulley (other pulley sizes available)
• 500 mm main blades
• 80 mm tail blades
http://www.goblin-helicopter.com/shop/imagesdesc/01.jpg
http://www.goblin-helicopter.com/shop/imagesdesc/02.jpg
http://www.goblin-helicopter.com/shop/imagesdesc/06.jpg
http://www.goblin-helicopter.com/shop/imagesdesc/11.jpg
http://www.goblin-helicopter.com/shop/imagesdesc/5.jpg
http://www.goblin-helicopter.com/shop/imagesdesc/3.jpg
    引用 momo0826 13-1-9 23:02
    sab产品线拓展的很快啊
    700 770 500
    引用 47812325 13-1-8 18:32
    价格不菲。。。。
    引用 晴忝尛豬 13-1-8 16:36
    舵机位置看着都新鲜,还是喜欢550的比例,正点
    引用 小雨HXL 13-1-8 10:38
    还是700过瘾........
    引用 自由大帝 13-1-8 02:49
    好东西~~~
    再这么下去SAB也会继续出小型机~~~
    查看全部评论(5)
