Kyosho 1/7油动版Scorpion XXL
13-1-25 03:46| 发布者: rcfans| 查看: 9974| 评论: 12
Kyosho京商的Scorpion(蝎子) XXL buggy电动版本上市已有一段时间,国内也聚集了一批爱好者。现在Kyosho推出配备了28级引擎,2.4Ghz遥控的Scorpion XXL。Scorpion XXL是京商新理念遥控车产品,2WD传动,630mm车身长度,车架设计和悬挂系统可以轻松应对任何地形。比1/8竞赛级卡车尺寸大了20%,但是比1/5汽油遥控车小了15%,用Kyosho的话说:“这种比例刚刚好”,轻松挑战1/8越野车场地。200cc油箱(一箱油接近15分钟行走时间),KS203金属齿大扭力防水舵机和2.4Ghz Syncro遥控器 (KT-201 & KR-200),3mm厚度铝制车架以及超大型避震器都是该车的标准配置。
->点击这里进入Kyosho品牌专区参与讨论
http://www.bigsquidrc.com/wp-content/uploads/2013/01/kyosho_gp_scorpion_xxl_3.jpg
http://www.bigsquidrc.com/wp-content/uploads/2013/01/kyosho_gp_scorpion_xxl_4.jpg
hose features and specifications include-
* XXL high performance nitro engine
* XXL tank with 200ml capacity for extra run-time
* High-performance chassis made ​​from 3mm aluminum
* Waterproof servos for steering & throttle/brake
* Water-resistant receiver box
* 2.4GHz Syncro KT-201 radio system
* Extra large oil shocks
* Full ball bearing drive train
* Engine stop switch for easy engine shut down
* Buggy body with roll cage, lights and figure
* Flip-top body design for easy access to the interior of the vehicle
* Adjustable turnbuckles
* Extra Large Sand tires
* 17mm hex hubs
* Extremely rugged heavy-duty drive train
* Externally adjustable slipper clutch
* Gull Wing Front Design
* Mid-engine chassis layout
* Fully functional side air channels
* Heavy duty side protection
* Fully equipped with Allen screws
* Length: 630 mm
* Width: 402 mm
* Height: 244 mm
* Track (F): 353 mm
* Wheelbase: 452 mm
* Gear ratio: 16:1
* Weight: 4,000 grams
* Engine: 4.6 cc Nitro
http://cdn9.rccaraction.com/wp-content/gallery/kyosho-ready-set-17-nitro-scorpion-xxl-buggy/31873t2b_4.jpg?8a12f1
http://cdn7.rccaraction.com/wp-content/gallery/kyosho-ready-set-17-nitro-scorpion-xxl-buggy/31873t2b_3.jpg?8a12f1
    引用 s13331698163 13-1-27 10:08
    不错
    引用 真我冻鱼 13-1-25 23:04
    28肯定不给力
    引用 我是down 13-1-25 14:10
    塑料太多了 该金属的不金属
    引用 facingfuture 13-1-25 11:11
    就这前下AB和前底盘仰角的设计就是给卖配件准备的.........这整车模样怎么看着都像那台复古的RTR电车~~~~~~~除了油箱大点实在没看出来哪里好,个人观点不供参考~~~~~
    引用 kzk.adu 13-1-25 11:01
    好车 想买   可惜 没米啊
    引用 bushwhacker 13-1-25 10:48
    .....200cc油箱啊, 1/8比例失误...发布换1/7吗?
    塑料倒是无所谓.....我的无刷Emaxx比我的Flux又轻又耐操,关键看设计匹配
    引用 pal 13-1-25 10:25
    一车的塑料件。。
    引用 王冲 13-1-25 09:36
    他可真能闹,能别闹了吗?
    引用 leiguoxiong 13-1-25 09:21
    喜欢希望不要太贵!
    引用 阳光小强 13-1-25 08:55
    我没看错吧,这么大的一个油箱。
    引用 mazha500 13-1-25 08:38
    不错啊 期待
    引用 炎焱 13-1-25 05:40
    好车~
    查看全部评论(12)
