![](http://www.teamxray.com/rx8/images/rx8-detail-zoom.jpg)
Features: - All-new fuel tank with interior baffles for stable engine performance - All-new Low Profile (LP) shocks - All-new lower alu shock bodies - All-new shorter shock rods - All-new fixed Delrin pistons - All-new Short Shock Springs (3S) - All-new front and rear lowered shock towers - All-new Reverse Clutch set for increased performance & durability - All-new shape of clutchbell - All-new clutchnut - All-new ultra-stable clutch spring - All-new redesigned front lower bumper for increased downforce, durability & stability of the car - All-new redesigned front upper bumper for increased durability - All-new redesigned rear lower arm 2-positions graphite shock holders for increased durability - All-new independent muffler mounting - All-new longer muffler wire - All-new front left bulkhead - All-new rear 2-speed shaft ball-bearing for increased durability - All-new rear right bulkhead for larger 2-speed shaft bearing - All-new stronger servo saver spring for increased steering and improved steering response - All-new steel servo saver pivot shaft for increased durability - All-new steel belt tensioner bushings for increased durability - All-new steel brake cam post for increased durability - All-new composite rear body holder for higher body mounting - Included optional lightweight front middle shaft from HUDY Spring Steel - Included optional lightweight alu brake disk adapter
![](http://image.rcfans.com/portal/201304/26/205023b8sey2wnymssjz55.jpg)
![](http://www.teamxray.com/rx8/images/gallery/gallery_20.jpg)
