Shepherd Velox V10 Pro 油动房车
13-8-9 11:37| 发布者: rcfans| 查看: 8971| 评论: 4
Overview Shepherd Velox V10 PRO new features
- Ball raced front and rear anti-roll bars
- Adjustable front lower roll-centre
- New front lower and upper wishbones
- New rear lower wishbones
- New front and rear shock tower made of German carbon fibre
- New front body mount plate made of German carbon fibre
- Adjustable small aluminium servo saver
- Wheelbase 2mm shorter
- Optimized shock position
- Rear upper arm replaced by a camber link system
- Lighter alunium bulkheads
- Smaller shocks in the rear
- Narrower and symmetrical chassis plate made of Swiss 7075 T6
Overview Shepherd Velox V10 general features
- Innovative 'Direct-V-Brake System'
- Well-proven 'Velox Revolutionary Shock System'
- 'Velox Competition Clutch' with extra strong spring
- Front and rear belt tension adjustable without disassembly
- Easy differential maintenance
- Front and rear CVDs included
- Super flat, vibration free, top mounted fuel tank
- Hard-coated aluminium pinions
- Quick roll-centre adjustment in the upper front
- Wheel axles mounted from the outside for easy maintenance and set-up
- Adjustable front and rear off-set
- Blue anodized aluminium bulkheads and hinge pin brackets
12
    引用 ROVERED 13-8-9 23:25
    拔凉拔凉的。。。
    引用 钱圣杰 13-8-9 21:16
    颜色很心情
    引用 wrfmy 13-8-9 16:52
    后面那个刹车么
    引用 lulutnt 13-8-9 12:30
    漂亮
