RB Products 推出 BXR 系列越野车用引擎
14-2-25 19:50| 发布者: rcfans| 查看: 51432| 评论: 2
RB Products 正式推出 BXR 系列越野车用引擎,包括 BXR LS5, BXR SLS3, BXR SLS5 和 LSDI5,每台引擎的详细参数请查阅下文。
BXR LS5:
  • Long Stroke
  • 5+2 Ports with MES
  • CNC machined piston
  • 14.5mm turbo shaft, lightened
  • Competition conrod
  • Turbo combustion chamber with integrated O-ring
  • 14.5mm high speed main bearing
  • Front dust protection rubber sealed bearing
  • Low gravity center & lightweight cooling head with 5° angle thins
  • Lightweight but strong crankcase
  • Composite slide carburetor (9mm)
  • 6, 7, and 8mm restrictors
BXR SLS3:
  • Super Long Stroke
  • 3 Ports with MES
BXR SLS5:
  • Super Long Stroke
  • 14.5mm turbo lightened crankshaft
  • 14.5mm high speed main bearing (ceramic)
BXR LSDI5:
  • Super Long Stroke
  • Direct Intake system
  • 14.5mm turbo and balanced shaft, lightened and silicone paste
    引用 lulutnt 14-2-25 21:33
    国内能买到?
    引用 不记事 14-2-25 20:48
    精致
