Feature list:
- Light weight chassis with simple 2 belt drive 4WD system.
- Famous racing engine brand, Star Motor, SIRIO 09 engine.
- One way unit for front, Ball Diff for rear.
- Front King Pin Suspension, new concept Rear Axle Suspension.
- Standard servos (including Mini servos) can fit. (Micro servos don’t.)
- Battery box for AAA with BEC connector.
- New “CRC-III” body, based on CRC-II, 1/12 EP racing, Fantom EP-4WD EXT Japan Nationals Winning Car in 1985.
- 2mm 17S duraluminium Main Chassis provides high stability, temperate flexibility, and better radiation of heat.
- Sponge tire, glued on 8 spoke wheel, has same quality as KRF Racing tire.
- Full Ball Bearing
- New 38cc fuel tank (approx. 5 minutes running time per a tank)
- 2 speed transmission as standard.
Technical Data:
*Length: 260mm *Width: 172/178mm *Height: 78mm *Wheelbase: 200mm *Tread: 147mm(F)/140mm(R) *Tire: 46×25mm(F)/50×38mm(R) *Gear Ratio: 5.89:1(1st)/4.62:1(2nd) *Weight: 1000g (w/Body) *Engine: Sirio 09
