AE为世界赛做好了准备,那就是B44 Features of the Factory Team B44: ? Composite front bulkhead and rear chassis plate for improved durability and more ground clearance ? Externally adjustable, dual pad slipper clutch ? 3mm woven carbon fiber shock towers ? 2.5mm woven carbon fiber main chassis and top plate ? Rear hubs use large .187 x .500 bearing for more durability ? Lightened ball differentials front and rear ? Shaft drive for unparalleled acceleration ? Slotted motor mount for quick and easy installation ? Blue aluminum center bulkhead cap with molded bearing inserts ? Ball bearing steering with adjustable servo save ? Hardened steel CVAs with cross pin retaining clips for ultimate reliability ? Front wheels and hexes are optimized to prevent hex stripping ? Hard anodized aluminum threaded shock bodies with Factory Team gold shock shafts ? Blue Factory Team titanium turnbuckles ? Blue Factory Team aluminum shock bushings ? Blue Factory Team aluminum servo mounts ? Blue Factory Team thumb screws and molded battery straps [ 本帖最后由 诺亚 于 2007-7-11 02:31 PM 编辑 ] |
