前两天 雷虎/Associated(以下简称AE)公布了即将推出新的B44四驱电越野。 这部新车是基于AE和Jconcept共同开发的BJ4世界赛版。 而B44只是个合作项目,Jconcept继续以独立的公司存在。 Jconcept继续发售BJ4套件,零件及附件。
Features of the Factory Team B44:
• Composite front bulkhead and rear chassis plate for improved durability and more ground clearance
• Externally adjustable, dual pad slipper clutch
• 3mm woven carbon fiber shock towers
• 2.5mm woven carbon fiber main chassis and top plate
• Rear hubs use large .187 x .500 bearing for more durability
• Lightened ball differentials front and rear
• Shaft drive for unparalleled acceleration
• Slotted motor mount for quick and easy installation
• Blue aluminum center bulkhead cap with molded bearing inserts
• Ball bearing steering with adjustable servo save
• Hardened steel CVAs with cross pin retaining clips for ultimate reliability
• Front wheels and hexes are optimized to prevent hex stripping
• Hard anodized aluminum threaded shock bodies with Factory Team gold shock shafts
• Blue Factory Team titanium turnbuckles
• Blue Factory Team aluminum shock bushings
• Blue Factory Team aluminum servo mounts
• Blue Factory Team thumb screws and molded battery straps
