http://www.teamxray.com/teamxray/news/newsdesc.php?news_id=1208&kategoria=1208&catName=&newsTitle=TECH%20TIP:%20XB8,%20XT8%20Diff%20Outdrive&Xnet_Session=9b518a2157b604ac99011819ac840ded Xray 因不想有漏油問題所以接杯軸,差速殼 , 盤齒生產公差收小 . 但又會導致差速過熱 , 轉動不順. 所以xray 建議你Diy加大公差吧 磨多少mm呢 ? 不會漏油嗎 ? [ 本帖最后由 JP 于 2007-7-26 08:47 AM 编辑 ] |
All XB8/XT8 diff parts are manufactured from very high tensile steel and as such all parts are specially hardened to provide extra long lifespan and minimal wear. After the hardening process the diff outdrives and inside of the diff gear and diff case are ground to achieve a smooth action of the diff outdrives in the diff assembly. All of the parts are precisely manufactured within very tight tolerances to minimize diff oil leakage; however, if some of the parts with tight tolerances meet together and the tolerances overlap, in some very rare cases the diff outdrives may not turn as smoothly as desired. In case you experience that the car starts to behave strangely and the handling of the car gets difficult after a few minutes of running and the differential becomes very hot, we suggest that you follow this Tech Tip. in some very rare cases ...... |
