AXIAL AX042 GREY GRAY HEAD SPEC 1s .32 NITRO ENGINE NIB Engine Specifications: Size .32cubic inch Maximum RPM 34,000 Bore 19.5mm Stroke 17.5mm Construction ABC Weight: 450g (15.87oz) Distance Between Mounting Holes Same Side: 21.10mm (0.830") Distance Between Mounting Holes Opposite Side: 36.97mm (1.455") Height Bottom of Mounting Tabs/Top of Cylinder Head: 97.55mm (3.84") Width of Mounting Tabs: 44.98mm (1.770") Distance from Pull Starter to Front Bearing: 83.38mm (3.28") Distance from Center of Engine to Front Bearing: 41.69mm (1.641") Distance from Center of Engine to Pull Starter: 41.69mm (1.641") Heat-sink Head, Anodized Aluminum Carburetor 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s) Carburetor Adjustments 3 Needle, Flush Settings Case Black Aluminum, Rear Exhaust Connecting Rod Dual Bushing Sleeve 8 port Starting system Pullstarter 请问如果我买了这个引擎.可以顺利装在Hellfire SS上吗? 还需要配个什么的死气喉?(烟通) 谢谢解答! |
