KYOSHO即将推出新款RRR
查看: 9176|回复: 32| [复制链接]
alkymt 论坛元老 发消息
发表于 08-5-8 18:03:54 |显示全部楼层 来自: 中国广东广州
个人感觉有好几个希望改进的地方
1.如果安装某些舵机臂,或者转向舵机安装太靠里面时,二楼板会影响转向舵机臂的动作,我安装9451做转向,就垫了垫片使9451不至于插进去转向舵机座太深
2.后避震器是否可以安装在油压架里面,而不是象现在安装在外面
3.可惜还是没看到有稳妥点的接收盒在车架上,毕竟比赛时接受机的安装位置很危险,虽然其它牌子有出品RRR的接收盒,但是毕竟原厂还是没去考虑,实在可惜
虽然不尽完美,但起码市场占有率还是证明了RRR是一款不错的车架,配件供应也充足
XMOLA 论坛元老 发消息
发表于 08-5-8 18:05:08 |显示全部楼层 来自: 中国广东中山
一大进步啊~RRR其实都是不错的
bbbb 超级元老 发消息
发表于 08-5-8 18:29:02 |显示全部楼层 来自: 中国上海
http://www.kyosho.com/jpn/produc ... ?product_no_1=31262
3mm7075t6底版,比原来的更细
离合器是m3的,二楼板很诱惑
sky825 元老 Fans 发消息
发表于 08-5-8 21:52:41 |显示全部楼层 来自: 中国浙江杭州
光是看看就流口水了,我什么时候才买的起啊
宁宁 超级元老 发消息
发表于 08-5-8 22:24:42 |显示全部楼层 来自: 中国北京
感觉没多少变化呀
kiro 金牌 Fans 发消息
发表于 08-5-8 23:24:15 |显示全部楼层 来自: 中国广东广州
底板使用7075 T6
具有kyosho 1/8平路车EVOLVA M3特征的新双速.
3.0mm 厚油压架
From adopting zero offset wheels which can do to give geometry of long-arm setting to the rear suspension.
FEATURES :
  • The mechanic plate which can give the gauge function of the left and right position of a vessel’s helm by meat pulling out form and angle.
  • Upper arm pivot from 5 places selective possibility. From the setting which decreases camber rate of change is possible.
  • The brake rotor of the both sides grinding finish, promising preeminent damping force and the highest braking feeling with adoption of the teflon brake pad.
  • With the adoption and the like of the aluminum brake hub from opening to goal the damping force which does not change.
  • Drive system of the gear and the main shaft etc. which are proud of the durability which is superior.
  • With inside diameter 13 Φ damper springs setting degree of freedom improvement.
EVO.2 Equip :
- Duralmin 7075 T6 material main chassis
- The adjustable type servo saber for EVOLVA M3
- 2D clutch & grey shoe
- 2 speed clutch shoes and steel ring specification 2nd gear spur gear for EVOLVA M3
- New form 3.0mm thick rear damper stay
- Zero offset wheels
- Capital trade original hexagonal driver (2.0mm) attaching
Chassis technical data
Total length385.5mm
Full-width200mm
Total height104.5mm
Gland clearance6mm
Wheel base260mm
Tread (F/R)174mm/170mm
Tire (F/R)Φ 61×26mm/Φ 63×30mm
Gear ratio7.63 / 5.33: 1
Gross loadApproximately 1,750g
EngineEach company 12 class (selling separately)
Propo2 ch2 servo
林林春春 论坛元老 发消息
发表于 08-5-8 23:33:13 |显示全部楼层 来自: 中国河南开封
看不出来有什么改动的地方啊
发表于 08-5-9 13:41:45 |显示全部楼层 来自: 中国上海
就算改动了也体会不出来把
SUGO 元老 Fans 发消息
发表于 08-5-9 14:04:45 |显示全部楼层 来自: 中国广东广州
KYOSHO 以前的RRR底板不是7075 t6的吗?
bbbb 超级元老 发消息
发表于 08-5-9 17:33:33 |显示全部楼层 来自: 中国上海
原帖由 SUGO 于 2008-5-9 14:04 发表
不是,v one系好像从没用过7075t6
