grail_2007 超级 Fans 发消息
发表于 08-5-19 01:05:29 |显示全部楼层 来自: 中国香港
主商品价格: 500元
姓名: 陳廣應
城市/地区: 深圳
IP: 219.79.89.78 - 香港特别行政区
AMD CPU 加 ECS底板
AMD SPEMPRON 2500+ CPU
ESC C51G-M754 底板
底板有盒有說明書,齊DRIVER碟
$500
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=581&CategoryID=1&DetailName=Specification&MenuID=48&LanID=0
CPU
Socket 754 for AMD Athlon™ 64/Sempron™ processor
High-performance Hyper Transport CPU interface.
Support transfer rate of 1600/1200/800/400 mega-transfers per second.
CHIPSET
NVIDIA GeForce 6100 & nForce 410
North Bridge: NVIDIA GeForce 6100
South Bridge: NVIDIA nForce 410
MEMORY
Single-channel DDR memory architecture
2 x 184-pin DDR DIMM socket support up to 2 GB
Support DDR400/333/266/200 DDR SDRAM
EXPANSION SLOT
2 x PCI slots
1 x PCI Express x1 slot
1 x PCI Express x16 slot
STORAGE
Supported by nForce 410
  4 x Ultra DMA133/100/66 devices
  2 x Serial ATAII 3.0Gb/s devices
  RAID0 & RAID1 configuration
AUDIO
Realtek ALC655 6-Channel audio CODEC
Compliant with AC'97 2.3 specification
LAN
Realtek RTL8201CL 10/100 Mbps Fast Ethernet PHY
REAR PANEL I/O
1 x PS/2 keyboard & PS/2 mouse connectors
4 x USB ports
1 x RJ45 LAN connector
1 x VGA port
1 x Parallel port (LPT)
1 x Serial port (COM1)
1 x Audio port (Line-in, Line-out, Mic-in)
1 x 1394a port(optional)
INTERNAL I/O CONNECTORS & HEADERS
1 x 24-pin ATX Power Supply connector
1 x 4-pin ATX 12V connector
1 x FDD connector supports two 360K~2.88MB FDDs
2 x IDE connectors
2 x Serial ATA connectors
2 x USB 2.0 headers support additional 4 USB Ports
1 x IrDA for SIR header
1 x Front panel switch/LED header
1 x Front panel audio header
1 x COM2 header (optional)
1 x SPDIF out header
1 x CD in header
CPUFAN/SYSFAN connectors
SYSTEM BIOS
Award BIOS with 4Mb Flash ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Supports ACPI revision 1.0 specification
FORM FACTOR
Micro-ATX Size, 244mm*224mm
sino 论坛元老 发消息
发表于 08-5-19 09:01:08 |显示全部楼层 来自: 中国广东广州
IP: 59.41.188.21 - 广东省广州市 - 电信
可能这位朋友不了解国内行情,图中的物品,在华南地区来讲,amd 2500+ 754针的约200     主板 应该约180左右   所以,你开出的价格就可能无人回复你落,呵呵呵:em01:
snowrose2000 终极 Fans 发消息
发表于 08-5-20 03:33:25 |显示全部楼层 来自: 中国辽宁沈阳
IP: 119.118.124.60 - APNIC
500块在沈阳可以买到双核3000+加主板了~~
