kiro 金牌 Fans 发消息
发表于 08-6-2 22:16:37 |显示全部楼层 来自: 中国广东广州
Kyosho dNaNo - Porsche Le Mans 917K
1/43 dNaNo AutoScale dNaNo FX-101
Porsche 917K
No.55 Le Mans 1970 Winner
Equipped and installed with special display parts that result in a high-grade display model.
Ultra realistic scale form can also be used on a running chassis.
  • Clear cover package and display stage make the model ready for immediate display.
  • Fully factory finished. Equipped with special display parts for an ultra realistic finish.
  • Fitting Parts Set (sold separately) enables the body to be mounted onto a moving chassis (sold separately) with realistic dimensions according to the body type.
< Set Contents >
  • Pre-painted plastic body finished with markings (with display-only chassis)
  • Tires / Wheels for display
  • Display Stage and Clear Box
Porsche 917K No.55 Le Mans 1970 Winner Technical Data
Length97.9mm
Width46.1mm
Hight24.0mm
Tires (F/R)Φ14mm×5.0mm/Φ16mm×7.0mm
kiro 金牌 Fans 发消息
发表于 08-6-2 22:17:14 |显示全部楼层 来自: 中国广东广州
Kyosho dNaNo - Ferrari 360 Modena
What is the Ferrari 360 Modena story?
Charging stallion wins the battle for aerodynamics and style.
The 1999 Geneva Motor Show was stunned by the pure elegance of the Ferrari 360 Modena body, which succeeded in making the existing trend for sharp-edged wedge shape body forms into a statement of style and sophistication. The Pininfarina designed Modena revived the aesthetic appreciation of Ferrari as automobile art, especially amongst Ferrari fans. The low and wide form sits at a height of only 1,215mm and was put through a total of 5,400 hours of wind tunnel testing to find the optimal balance between style and aerodynamics. A 3.6 liter 90 degree V8 engine produces more than 400hp in a true road going racer.
< Set Contents >
Ferrari 360 Modena Technical Data
Length104.5mm
Width46.4mm
Hight28.0mm
Tires (F/R)Φ15mm×4.0mm/Φ16mm×5.5mm
Source : Kyosho
mouseyy 超级元老 发消息
发表于 08-6-2 23:33:35 |显示全部楼层 来自: 中国广东广州
第一台的PORSCHE好丑哦,塑料材质象拖鞋,底盘还不平,前轮都没完全着地,整一玩具样。
那台MODENA还象那么回事。
wen.jc 超级元老 发消息
发表于 08-6-3 02:13:40 |显示全部楼层 来自: 中国广东深圳
塑料材质象拖鞋
版主一针见了血!!哈哈哈哈
sonybmg 高级 Fans 发消息
发表于 08-6-3 16:41:54 |显示全部楼层 来自: 中国广东广州
都系787B好睇
叛逆的蚊子 超级 Fans 发消息
发表于 08-6-3 16:51:29 |显示全部楼层 来自: 中国广东深圳
官方照片都只能拍成这样!!~!估计~~~~~呵呵!!~!
柴柴 超级元老 发消息
发表于 08-6-3 23:30:14 |显示全部楼层 来自: 中国广东广州
917K正,应该会出gulf花,不知道会不会出longtail
gerry2001 论坛元老 发消息
发表于 08-6-8 20:06:29 |显示全部楼层 来自: 中国广东东莞
我不明白,这么Q的dNANO,却带个大好多倍的遥控 搞个超小遥控配合一下不好吗??
