Trinity为MINIT推出一套车灯套件。![]() Description: Trick out your favorite Mini-T body with these "Xenon" style light sets. Includes both high and low beam headlights, rear running lights and reverse lamps. Low beams and rear running lights are always lit while the high beams light when going forward and the reverse lamps light when going in reverse, so your competition will be sure to see you coming! Easy to install in only minutes. Looks killer when installed in our new "Home Brew Hauler" (TRI39751) and "Maxzilla" (TRI39752) bodies!!! Item Number: TRI34073 Retail Price: 19.99 Available: 4/1/2004 |
