ego 超级元老 发消息
发表于 08-7-19 13:48:00 |显示全部楼层 来自: 中国广东广州
ego 超级元老 发消息
发表于 08-7-19 13:49:18 |显示全部楼层 来自: 中国广东广州
Available: August 2008
    Redesigned Main Chassis - New main chassis features narrow dimensions and unique flexible front section. Newly developed main chassis uses 7075 T6 Duralumin that results in a tough yet flexible design. Lighten Upper Deck - Revised upper plate design cuts out unnecessary weight and not only looks sharp but produces excellent control characteristics on high-speed layouts. Updated 2 Speed Transmission - Use of the same 2-speed clutch shoe, steel ring and spur gear as the EVOLVA M3 improves gear shift feel and enables faster maintenance. New Rear Shock Stay - New shape 3.0mm thick shock stays improve rigidity during suspension stroke and crash endurance. Improved Brake System - Brake rotor machine polished on both sides with Teflon brake pads that deliver subtle brake feel and effective braking power. Aluminum brake hub promises reliable braking power from start to finish. New Clutch Set Up - The new V-One RRR EVO2 is now equipped with the latest 2D clutch set up and gray clutch shoe, this improvement results in smother engagement which reduces wear and tear on your drive train. M3 Servo Saver Upgrade - The New fully adjustable servo saver was adopted from the Evolva M3 which gives you endless adjustments. Choice of 5 positions for upper arm pivots enables setting for reduced camber change rate. Drive system boasts high durability gears and drive shaft. 13mm diameter shock springs provide increased scope for setting options. Hex head screws
  • Zero offset wheels
Technical Specifications
  • Scale: 1:10
  • Width: 200mm
  • Length: 385.5mm
  • Height: 104.5mm
  • Wheelbase (min): 260mm
  • Weight: 1750g
DYGM 超级元老 发消息
发表于 08-7-19 19:15:32 |显示全部楼层 来自: 中国北京
蛮性感的,可是为什么FM的接收机那么短的天线?全藏在设备仓里面了?!
hooperter 终极 Fans 发消息
发表于 08-7-19 20:07:41 |显示全部楼层 来自: 中国台湾
新車都搭載DSM接收
遥控大猫 超级元老 发消息
发表于 08-7-20 13:51:11 |显示全部楼层 来自: 中国北京
回复 3# 的帖子
美观
FISH喔! 终极 Fans 发消息
发表于 08-7-22 23:07:50 |显示全部楼层 来自: 中国广东广州
还是换汤不换药...
lp翔 金牌 Fans 发消息
发表于 08-7-24 17:35:03 |显示全部楼层 来自: 中国广东广州
好车不必改太多······
