AWD 2.4G套装
Precision palmtop sized shaft-driven AWD chassis now fitted with 2.4GHz Radio unit.
Lower chassis height enhances scale realism.
Precision differential gears on front and rear on the shaft driven AWD power train combine with the four-wheel independent suspension for awesome performance way beyond its scale. Whether on-road or off-road, AWD (all-wheel-drive) is regarded as one of the ideal racing platforms. The sophisticated mechanics of AWD have been condensed into a dropped palmtop size chassis and combined with the ASF 2.4GHz control unit for the ultimate in control stability. Body styles that suit low height chassis are now even more real. Also, the kit without transmitter specifications are ideal for those who already have an ASF 2.4GHz MINI-Z Racer. Now you can add the MINI-Z AWD as your 2nd or 3rd MINI-Z at an even more reasonable cost.
Source : Kyosho |
