无间道 论坛元老 发消息
发表于 08-10-31 00:11:34 |显示全部楼层 来自: 中国广东广州
Tamiya为了庆祝F103车架诞生15周年推出的特别版F103限量车架!使用3.2mm碳纤底板,车架印有纪念版本的logo,相信会是Tamiya收藏者的心头好
The Anniversary Logo on the upper and lower carbon fiber plates, and high precision aluminum servo mount feature only on this limited edition anniversary kit.
This kit adopts a new carbon fiber T-bar bridge. As shown in the images above, blue dress-up parts such as the Aluminum battery posts and body mounts provide beautiful highlights.
Specs
  • 3.2mm Carbon Fiber Chassis w/Anniversary Logo
  • Long Carbon Fiber Upper Deck w/Anniversary Logo
  • Newly Designed Aluminum Servo Mount
  • Carbon Fiber T-Bar Bridge
  • Teflon Friction Plate
  • Carbon Fiber Friction Plate
  • Pre-Attached sponge Tires
  • Height Adjustable Aluminum Differential Housing
  • TRF Damper (F103GT)
  • Carbon Fiber Rear Shaft
  • 4mm Aluminum Lock Nut
  • Aluminum Turnbuckle Shaft
  • High Torque Servo Saver
ELECTRIC KITS REQUIRE:
(unless stated differently above)
  • Radio: 2-Channel with servo(s)
  • Battery: 6-cell flat with standard Tamiya connector
  • Charger: AC/DC timed or peak for 6-cell battery
  • Paint: PS for Polycarbonate/TS for ABS
  • Misc. Items: Building and track equipment
囧漂RC 论坛元老 发消息
发表于 12-3-25 19:25:42 |显示全部楼层 来自: 中国广东深圳
论坛新区顶一下。。。
凡阿特 金牌 Fans 发消息
发表于 12-3-25 23:03:06 |显示全部楼层 来自: 中国江苏南京
要是直接能放锂电就好了
caolemeng 超级元老 发消息
发表于 12-3-28 16:11:45 |显示全部楼层 来自: 中国河南洛阳
要是直接能放锂电就好了
aetc3 超级元老 发消息
发表于 12-4-12 18:16:36 |显示全部楼层 来自: 中国浙江杭州
F103都可以放锂电
