nivea 金牌 Fans 发消息
发表于 08-11-4 16:17:46 |显示全部楼层 来自: 中国广东广州
kyosho VoneS一直是入门和中级油房的最佳选择,12月S3将会有新的款式推出
V-ONE SIII Evo将采用和Kyosho Vone大哥的世界冠军车R系列相同的悬挂系统和双速. 新设计的底板,维护更容易,更换零件更轻松. 搭载GXR15手拉发动机!2008 KYOSHO CUP 将开始认可这款新车参赛!
Evo. Special Features
  • Long swing shafts on front prevent shafts dropping out for greater reliability.
  • Hardened material in the main shaft reduces risk of gear failure.
  • Modified angle of the throttle linkage lever realizes a linear control feel.
  • Fuel tank features special cap for smoother fuel flow.
  • Servo horn with thicker serration achieves increased strength.
  • Easy chassis height setting with dial-adjustable oil shocks.
Focus on a lower center of gravity encompasses all aspects of design, including the radio plate. The result is astonishing maneuverability.
Chassis layout and design deliver easy maintenance features such as fast spur gear replacement.
Material design matches flexibility with rigidity to maximize suspension performance.
Neutral steering characteristics are achieved through greater lateral control balance and more setting options.
Dial-adjustable oil shocks enable easy and precise setting of chassis height.
Reinforced radio box hatch results in greater durability and easier maintenance.
Setting angle of the throttle linkage lever produces a linear control response to throttle trigger input.
After claiming the driver’s title in the GT300 class in the 2007 SUPER GT series, the MR-S of the ‘apr’ Team was relaunched in 2008 with the main character from the hit animated Disney/Pixar movie ‘CARS’. Even the team name was changed to ‘Lightning McQueen’. The red MR-S wore the same graphics from the movie and drew plenty of younger fans while participating in dramatic racing action, just like in the movies!
Chassis Technical Data
Length440mm
Width200mm
Height115mm
Ground Clearance8mm
Wheelbase260mm
Tread (F/R)176mm
Tire(F/R)Φ 64×24mm
Gear Ratio8.13 / 5.6:1
Weight1,850g (approx.)
EngineGXR15
GT27 超级元老 发消息
发表于 08-11-4 18:44:43 |显示全部楼层 来自: 中国吉林长春
就是一顿瞅啊 ,用力瞅啊,除了车壳、电池盒压板、接受盒压板,没区别呀 哈哈
底盘也和我们一样 究竟 EVOLUTIONG 在哪儿了呢?
Lancervii 超级元老 发消息
发表于 08-11-4 18:48:07 |显示全部楼层 来自: 中国贵州贵阳
KY专门为 KY 杯  出的S3  竞赛版本
GT4 论坛元老 发消息
发表于 08-11-6 10:26:05 |显示全部楼层 来自: 中国上海
KY 杯  出的S3  竞赛版本,这个车车买了随便跑跑应该不错。跑街合适
huqim 金牌 Fans 发消息
发表于 08-11-6 11:08:17 |显示全部楼层 来自: 中国广东佛山
一样的天空
XMOLA 论坛元老 发消息
发表于 08-11-6 11:27:40 |显示全部楼层 来自: 中国广东中山
又是换汤不换药出来骗钱的货色
宁宁 超级元老 发消息
发表于 08-11-6 13:52:55 |显示全部楼层 来自: 中国北京
还没我升级的多
爱宝宝的宇 高级 Fans 发消息
发表于 08-11-7 07:15:45 |显示全部楼层 来自: 中国上海
没有多大变化啊!
cu_boy 长老 Fans 发消息
发表于 08-11-7 21:32:41 |显示全部楼层 来自: 中国北京
始终是经典~
发表于 08-11-7 21:54:50 |显示全部楼层 来自: 中国山东青岛
