nivea 金牌 Fans 发消息
发表于 08-11-4 16:21:06 |显示全部楼层 来自: 中国广东广州
kyosho的世界冠军油房Vone R系列有新产品发布V-ONE RRR Evo.2世界赛版,全车加入多个升级零件!
  • With a choice of 5 different upper-arm pivot-mounting locations, setting for lower camber change rates become possible.
  • Brake rotors polished on both sides and Teflon brake pads give a feeling of sensitive yet powerful braking.
  • Aluminum brake hub provides stable stopping power from start to finish.
  • Drive system features high durability gears and main shaft.
  • Shock springs with inner diameter of 13mm provide free scope for setting adjustments.
Belt driven 4WD Evo. version of the 2004 World Championship winning machine (the first RRR version) has evolved even further. Now the 2008 World Champion!
Upper plate, cut and shaped to remove unnecessary weight, combines with dynamic main chassis for superior control on high-speed courses.
Uses the 2-speed clutch shoe and steel ringed 2-speed spur gear of the EVOLVA M3 for improved sense of speed changes and faster maintenance.
New design 3.0mm thick rear shock stay contributes to higher rigidity during suspension stroke and stronger crash resistance.
Features hex bolts throughout for greater rigidity, as expected of a high-end model.
Suspension arms designed 2mm longer for geometry delivers zero offset wheels on the rear suspension.
WC Team Edition Special Features
●Universal joints on front and rear (VZW219, VSW006)
●φ9mm hardened ball screws
●Rear adjustable stabilizer
●Adjustable rod (for rear adjustable stabilizer)
●Muffler stay holder (Aluminum)
●Aluminum drive washer
●SP drive belt (front, middle, rear)
●FRP battery plate
●FRP middle plate
●Hollow middle shaft
●Aluminum one-piece engine mount
●Titanium coated shock shafts (30mm)
●Lightweight 1st gear housing
●Sealed bearing 6×10x3mm (for servo saver)
Evo.2 Special Features
  • Duralumin 7075 T6 main chassis
  • New Upper Plate
  • Adjustable type servo saver from EVOLVA M3
  • 2-speed spur gear with 2-speed clutch shoe and steel ring from EVOLVA M3
  • New shape 3.0mm rear shock stay
  • 2D Clutch & Grey Shoes
  • Hex head screws
  • Zero offset wheels
  • KYOSHO Original hexagon screw driver (2.0mm)
Evolution of the Evo. to the Evo.2
Super strong 7075-grade T6 Duralumin main chassis features narrow design and grooved for reduced weight.  Front end flexibility realizes smooth surface tracing.
Chassis Technical data
Length385.5mm
Width200mm
Height104.5mm
Ground Clearance6mm
Wheelbase260mm
Tread (F/R)174mm/170mm
Tire(F/R)Φ 61×26mm/ Φ 63×30mm
Gear Ratio7.63/5.33:1
Weight1,750g (approx.)
R/C System2-channel, 2-servo system for cars
falpsp 终极 Fans 发消息
发表于 08-11-4 17:23:23 |显示全部楼层 来自: 中国四川成都
好车车啊!!!!
我是菜鸟!!!
还麻烦高手讲解一下都有哪些升级件!!!!
DYGM 超级元老 发消息
发表于 08-11-4 19:37:17 |显示全部楼层 来自: 中国北京
油房大菜鸟看不出门道……但是感觉看起来很好……
发表于 08-11-4 21:16:40 |显示全部楼层 来自: 中国北京
