Car will come equipped with all the best Capricorn Hops-up :
- 08 World champion clutch edition,
- monolithe brake disk,
- one piece engine mount
- main and middle lightened shaft
- ultra light pivot balls
- ultralight rear dogbones
- ultralight front CVD
- Monolithe front and rear HEX wheel hub
- front and rear 3,6mm shocks stay
- 38mm 2nd spur gear diameter ultralight weight
- 42mm 1st spur gear diameter ultralight weight
- front WIRED anti roll bar
- new front belt tensioner system
- read HEX hub belt tensioner
- REAR UPPER ARM
- New innovative plastic material for ARM’s,HUB’s
