dairy 金牌 Fans 发消息
发表于 04-9-30 10:30:00 |显示全部楼层 来自: 英国
[upload=jpg]picture/offroad/200493010274031277.jpg[/upload]
[upload=jpg]picture/offroad/200493010275968834.jpg[/upload]
O.S. Engines has developed a killer new .18-size small-block engine that's even more powerful than the class-leading .18 CV-R, and it's a direct fit for the T-Maxx. The .18 TM features an IPS-type crankshaft to fit the stock clutch and flywheel hardware from the 2.5 T-Maxx, and the Traxxas EZ Start 2 or a Traxxas pull-starter are a direct fit on the .18 TM.
The .18 TM features a 16mm bore and 15mm stroke for true 3cc (.18 c.i.) displacement. Quality ABC construction, a knife-edged conrod, skirted piston, 3-needle carb, and an included header with silicone gasket and high-quality retainer spring. These features combined with legendary O.S. quality make this one the most promising aftermarket engines with versions for use in any current production Traxxas truck (Another version will be available shortly that will include a header for installation in the Revo).
疯狂活塞 超级元老 发消息
发表于 04-9-30 10:53:00 |显示全部楼层 来自: 中国上海
小日本OS也开始直接翻砂了啊,不进行表面处理了
手拉盖也变样啦
