Toyota Aristo或者叫做Toyota Lexus GS 车壳被加入到TT-01Type E Drift 车架套件内,同时这个产品还装备了Tamiya LED l灯组 TLU- 01, 头灯、尾灯.
- Length: 460mm, Width: 187mm, Height: 140mm.
- Based on the lightweight and user-friendly TT-01E chassis for effortless assembly.
- 4WD shaft driven bathtub chassis with coil spring damped, 4-wheel independent double wishbone suspension and sealed front and rear differential gearbox.
- Drift-spec modifications include special suspension tuning, full ball bearings, RS-540 sport tuned motor, aluminum heat sink, CVA super mini shock dampers and short springs and adjustable upper arms.
- Polycarbonate body and newly designed font and rear light cases capture the Aristo’s beautiful form.
- Installed on the stylish wheels are Super Driftech tires which are specially designed for long-lasting drift action. (24mm, offset +2)
- Includes Electronic Speed Controller (TEU-101 BK).
- Includes LED Light Unit (TLU-01) and 2 x white LED’s (Front) and 2 x red LED’s (Rear).
- Add separately available LED lights for a greater sense of realism.
- Add Tamiya LED Light Control Unit (TLU-02) Item 53937 for more control of light operations.
- Wide variety of tune-up parts are separately available to further customize your machine.
- 2-channel R/C system, battery pack and charger separately required.
