Kyosho不清楚,Novak最近是推出一个新的ESC,叫做Super Duty XR High-Voltage ,支持双马达。主要为大脚车设计。看图: Novak’s new Super Duty XR High-Voltage Reversible ESC is designed for electric monster trucks like the Traxxas E-Maxx, Kyosho Twin Force, Tamiya’s TXT-1, etc. The ESC uses Novak’s Smart Braking II feature (which allows a full range of braking without accidentally sending the vehicle into reverse) and it can handle 6-14 cells which means you can use dual 6 or 7-cell packs. Other features include Thermal Overload Protection; One-Touch Set-Up; and gold-plated Direct Solder Wire Tabs. [此贴子已经被作者于2004-10-22 5:47:29编辑过] |
