nivea 金牌 Fans 发消息
发表于 09-5-12 21:34:42 |显示全部楼层 来自: 中国广东广州
Kyosho - DRX Subaru Impreza WRC 2008, 18级发动机,7月上市
Engine sound of real detail and power.
Running of a genuine scale model is here.
Aggressive running as which tarmac and Glaber do not choose road to say nothing of R/C exclusive use off-road course. A light exhaust note is sounded, and power where it runs through by the power feeling only of GP is exactly reproduction of the WRC machine. The performance where a dimension of exquisiteness based on a long wheelbase and 4WD full-time chassis of three [defu] equipment are achieved changes a familiar place into the circuit. Manoeuverability to be able to enjoy steady straight advancement and the drift control’s having room offers a new, driving experience of it not is before. The world of the rally car with deep elegance is achieved with running to accompany the squeal sound of the roll and the tire of the body that is reminiscent of a real car and a real body. Please enjoy the drama of a refreshing running.
Features :
  • Includes full body decals and scale of different body parts with the headlights with clear lenses.
  • RIKOIRUSUTATA with the amount of slack GXR18 comes with the engine exhaust.
  • Provide excellent throttle response is a separate type of clutch used in RESHINGUBAGI.
  • Maintenance of long cycles in large-capacity air cleaner.
  • Offset down to the mouth exhaust mufflers, unnecessary damage the body, such as hole scale.
  • Standard equipped with oil dampers in large type ride height adjustment.
  • 4 boxes that combine the mechanical maintenance and dust can be removed with screws.
  • DYUARUDISUKUBUREKI with front and rear individual settings.
  • 103cc fuel tank that can travel more than 10 minutes.
  • Also adopted KUIKKUOPUNA tank cap in the race and stay for transponder equipped.
  • Ride height and camber, tread, front & rear toe-sets can be subject.
  • The spring clutch of the options available in setting the PAWAFIRU KURATCHISHU.
  • The attachment of the optional stabilizers, further high-level driving performance.
RIKOIRUSUTATA equipment GXR18 afford to employ the power the engine. In a separate clutch, accelerator response achieved utilizing the running.
A length and wheelbase chassis, a low center of gravity designs that turn on full-time 4WD of three [defu] equipment, and excellent suspensions announce running that doesn’t choose the road.
And divert some of the knuckle of the left and right suspension arm and all around, while considering the economy, won the outstanding maintenance.
To prevent wheel lock and a lock equipped with a guard to prevent ingress of foreign material inside the wheel knuckle, full combat gear, and based on race.
Consideration to increase the stroke of the four-wheel independent suspension, high-speed exercise in the region to follow a stable surface. Won the outstanding stability.
Larry pattern hollow rubber tires of the attention and sense of scale and wheels, and thoroughly embedded in the body designed by the headlights with clear lenses.
Subaru Impreza WRC 2008 is?
WARUDORARIKA based on the 2007 Subaru Impreza released new year, the Subaru Impreza WRC 2008. The main theme was developed to improve the steering stability, have been designed and RONGUHOIRUBESU SHOTOOBAHANGU. Also been implemented across a lightweight, AWD SHINMETORIKARU maturation and specification of further highlight the characteristics of the chassis for low center of gravity Boxer engine and the horizontal counter. The basic design of the blue like this, a new image with a combination of a new line of white and silver in 2008, the World Rally Championship without a fight, as a threat to international team in the world list of Suva drew a passionate enthusiasm.
Kits Include :
# Chassis Kit Assembly
# RIKOIRUSUTATA GXR18 with engine
# Clear Body
# Scale Tires
# Wheel scale
# Decal
# UINDOUMASUKINGUSHITO
# Support their professional point servo horn
# Allen wrench 4 species
# Cross wrench
Specification :
  • Overall length 560mm
  • Width 260mm
  • Height 187mm
  • Wheelbase 316mm
  • Tread (F / R) 215mm / 215mm
  • Tire (F / R) Φ93×38mm / Φ93×38mm
  • Gear Ratio 8.86:1
  • Gross weight Approximately 2,600 g
  • Engine RIKOIRUSUTATA equipment GXR18
ktcckc001 长老 Fans 发消息
发表于 09-5-12 21:40:00 |显示全部楼层 来自: 中国浙江金华
沙发下!!!
littlecat 超级元老 发消息
发表于 09-5-13 01:07:39 |显示全部楼层 来自: 中国山西太原
拉力车~~~~~~
nightkiss 超级元老 发消息
发表于 09-5-13 17:06:04 |显示全部楼层 来自: 中国广东湛江
不会吧,,,长度是560mm???是1比7?,,但是看到它的狗骨,,还是DBX的狗骨,,很细小,,对这车抱保留态度。。。
金属兔子 论坛元老 发消息
发表于 09-5-13 22:14:35 |显示全部楼层 来自: 中国山西太原
真漂亮! :em07:
thome123 论坛元老 发消息
发表于 09-5-14 00:20:18 |显示全部楼层 来自: 中国广东佛山
爽``能看到真车就好了````
foolsfools8 论坛元老 发消息
发表于 09-5-16 12:54:58 |显示全部楼层 来自: 中国河北张家口
这个大概要多少钱??
probygy 超级 Fans 发消息
发表于 09-5-16 14:20:17 |显示全部楼层 来自: 中国山东济南
非主流。。。
发表于 09-5-18 21:14:08 |显示全部楼层 来自: 中国北京
