1/43 全比例蚊车,真牛! 用3节电池,3.6V 120mAH,全比例遥控是最牛的,而且可以用任何标准27M的发射机,比MiniZ等的通用性都强。不过,看舵机挺大个的,怎么能放的进去啊。主电机到是不大,奇怪。另外,价格够贵,$70,赶上MiniZ啦。不知道速度怎么样,说Spec2 比Char-G 快一点。Char-G 有多快?谁知道。 An Epoch 1/43 is a FULLY proportional radio control car. They come in two varities Spec 1 (this includes the Speed Racer Mach 5) and Spec 2. They come with charger, radio, and 1 set of AM 27mhz crystals. The remote takes 1 9v and the charger takes 6AA. The car comes complete with 3 NiMH batteries. http://www.microrccars.com/mods/epoch_indoor_racer/ |
多些壳就好了。有无1:43的静态车壳换装? 他没说比BIT CHAR G快哦,比Digi Q快而已 The Spec 1 is slower than a Digi Q. The Spec 2 is slightly faster than a Digi Q. Neither can compare to a stock Mini Z. The only known way to increase speed is to get a lighter body. [此贴子已经被作者于2005-2-3 17:19:48编辑过] |
