High-end Drift Chassis Kit(漂移车) The design chassis only for the drift of shipping schedule pre-bid price \49,800 expectation of July of high-end drift chassis kit 【 tentative name 】 appears. The motor made of aluminum mount is arranged in [roadekki] made of the carbon in [furontomido], and the best weight balance for the drift running is achieved. The maximum feature is “Double upper frame” that vertical (vertical) mount is done. The rigidity in the direction of the pitch (Before and behind) was high, and it was assumed in the direction of the roll (right and left) a flexible chassis characteristic made of the carbon of 2mm thickness. The steering wheel system that becomes an important factor with the drift chassis improves a right and left tire slice corner, and parallel (parallel) geometry that runs side by side is adopted and the control at counter steering has been improved. TA05 bulk head, 37T/18T Pulley, [sho-toriba-shiburusasua-mu], and upright TRF416, etc. are choice as for parts up to now, in the touring car with results. A lot of OP parts of the TA05 faction that abundantly becomes complete can be used. The new size front and rear belts, rear belt is × 2, front × 1. Furontoborudefu drive system, Riyadairekutokappuringu, universal shafts around, TRF damper equipped. It is possible to use it ..[tamiyaguranpuritsu-ringuka-kurasu] (double deck object)… |
