马达相当与9T的马达哦 The NOSRAM Storm Brushless Modi-fied is an extremely powerful modified motor in brushless de-sign the perfect choice for the NOSRAM Matrix Brushless+Brushed speed control. Power like a hot 9 turns modified brushed motor to burn some rubber on the racetrack, but without any maintenance required on brushed motors. No comutator, No brushes, No springs to wear = zero mainte-nance!!! Spend more time behind the driv-ing wheel of your transmitter and not in the pits!!! Features: Brushless Motor in sensored design 46.800rpm 3.53Nmm/A = kt 6.500rpm/V = kv 255W power 92% efficiency 4.8-8.4V adjustable timing The NOSRAM Matrix Brushless+Brushed speed control is based on sensor technology = constant data flow between the speedo and motor during the run. The result of this state-of-the-art sensor technology is an intelligent system with ultra pre-cise throttle control, linear drive feel and a fully adaptive software. The Matrix Brushless+Brushed is actually 4 SPEED CONTROLS in 1 = Brushless mode: Forward/Brake/Reverse and Forward/Reverse; Brushed mode: Forward/Brake/Reverse and Forward/Brake. With the race proven Power-Management-System 2, the punch, initial brake and automatic brake of the speedo can be adjusted to the specific needs of the driver. Features: Brushless AND Brushed Sensored Technology 4 speed controls in 1 Motorlimit over 5.5 turns (Brushless), over 7 turns (Brushed) PMS-2 software 4 modes: with Forward/Brake/Reverse and Forward/Brake selection, punch control, initial brake and automatic brake Small size: 33x38mm Light weight: 24g External solder tabs Race legal: IFMAR, ROAR, EFRA, BRCA! Matrix brushless + brushed speed control # 90500 |
