YOKOMO BD最新消息
查看: 6228|回复: 19| [复制链接]
jetso 论坛元老 发消息
发表于 05-3-29 11:46:00 |显示全部楼层 来自: 中国广东广州
Coming soon is Yokomo's 'new generation' belt-drive 4wd touring car.
The MR-4TC BD is packed with features to provide today's racer with 'next level' performance, adjustability, and ease of maintenance.
Listed below are features you can expect to see.
• 2 belt drive system
• large diameter pulleys
• long rear belt
• front and rear aluminum bulkheads
• adjustable front and rear belt tension (via adjustable cams located inside bulkheads)
• aluminum front belt tensioner
• full ball bearings
• battery tray system (compatible with multiple sub-c battery brands)
• new material suspension arms (for enhanced durability)
• carbon graphite main chassis, upper deck, shock towers
• low mount upper deck
• front and rear universal driveshafts
• front and rear aluminum suspension mounts (split type mounts for easy belt removal)
• aluminum motor mount
• aluminum servo mounts
• front and rear sway bars
• titanium turnbuckles
• RAYSPEED springs and spring retainers
• aluminum steering bellcranks
• rear bumper
Prototype front one-way with large diameter pulley shown.
New battery tray system is compatible with multiple sub-c battery brands. Filing of the battery slots not required!
Steering assembly utilizes aluminum bellcranks and a graphite center plate for precise movement and better fit.
jetso 论坛元老 发消息
发表于 05-3-29 11:47:00 |显示全部楼层 来自: 中国广东广州
Aluminum suspension mounts are used for precise toe alignment. RAYSPEED springs and retainers are also included.
Aluminum bulkheads and motor mount are designed to allow easy access to the entire drive system. Both front and rear bulkheads feature an adjustable cam-type system for precise belt tension adjustments.
All images shown are of a prototype sample. RAYSPEED body not included. Features and specifications subject to change without notice.
PART# DESCRIPTION STREET PRICE AVAILABILITY
MRTC-BD1 MR-4TC BD CHASSIS KIT $420.00 Late Mar '05
- Radio transmitter, receiver, steering servo
- Micro-sized electronic speed controller
- Electric motor (540 size)
- 6-cell sub-C battery pack (non-stick pack)
- Battery charger
- Rubber racing tires (24mm)
- CA glue for gluing tires
- Polycarbonate racing bodyshell
- Polycarbonate paint
- Refer to assembly manual for list of required tools.
忆の伤 论坛元老 发消息
发表于 05-3-29 16:04:00 |显示全部楼层 来自: 中国北京
喜歡~
发表于 05-3-29 17:45:00 |显示全部楼层 来自: 中国广东广州
结构比415好
老大 终极 Fans 发消息
发表于 05-4-3 21:38:00 |显示全部楼层 来自: 中国北京
好车,顶!
ytht 金牌 Fans 发消息
发表于 05-4-3 21:40:00 |显示全部楼层 来自: 中国广东广州
还是xray 05 FK比这实在。
忆の伤 论坛元老 发消息
发表于 05-4-4 18:26:00 |显示全部楼层 来自: 中国北京
多少米?
council 长老 Fans 发消息
发表于 05-4-4 18:51:00 |显示全部楼层 来自: 中国广东广州
以下是引用忆の伤在2005-4-4 18:26:41的发言:
多少米?
比xray 05 FK贵,个人认为不值得。
SHUAI 中级 Fans 发消息
发表于 05-4-14 18:34:00 |显示全部楼层 来自: 中国广东佛山
好车!
忆の伤 论坛元老 发消息
发表于 05-4-14 18:58:00 |显示全部楼层 来自: 中国北京
以下是引用council在2005-4-4 18:51:30的发言:
      [quote]以下是引用忆の伤在2005-4-4 18:26:41的发言:
多少米?
[/quote]看来要买的话我从现在起~连泡面都吃不上了~
