council 长老 Fans 发消息
发表于 05-5-19 08:49:00 |显示全部楼层 来自: 英国
Pro4等房车使用。
New low friction competition shocks from HPI for the Pro 4 and other high end touring cars.
These new shocks have been developed by the HPI Racing team for best on track performance.
- A new harder bladder in the shock cap gives more consistent rebound.
- The new design of the O-ring and retaining cap reduces friction on the shock shaft.
- New designed pistons give a precision fit inside the shock body for optimized oil flow.
The result is an overall smoother operation which gives the car better traction and more consistent handling on the track.
Andy Moore: "It is unbelievable the difference these shocks make!"
75194 - Competition Aluminum Threaded Shock Set (46-56/2pcs)
[此贴子已经被作者于2005-5-19 9:00:28编辑过]
Rovered 超级元老 发消息
发表于 05-5-19 16:14:00 |显示全部楼层 来自: 中国福建厦门
又什么高科技产品/?
发表于 05-5-19 09:12:00 |显示全部楼层 来自: 中国广东广州
低阻力是不是代表比较容易漏油
415MS的避震只有一个O圈来密封,时间放久了就有油漏出来
zyjohnny 元老 Fans 发消息
发表于 05-5-19 14:41:00 |显示全部楼层 来自: 英国
Andy Moore: "It is unbelievable the difference these shocks make!" [em39][em39][em39]  他不会在骗人吧!哈哈!
