council 长老 Fans 发消息
发表于 05-6-10 08:19:00 |显示全部楼层 来自: 英国
以前做18仔的,现在竟然推出1:10的房车了。都是RTR来的,都是直轴车,可能比较适合新入门的fans了。
Most known from A-tech are their 1/18 scale cars, but soon to be rleased from them are two new Touring cars, one electric and one nitro.
The electric TC will be a 4WD shaft type RTR, and is including battery, charger, motor, servo, receiver and ESC. Bodies inckuded will be either the Stratus or Mazda 6, both manufactured by Proline.
- Front and rear double wishbone suspension
- Equipped with C-hub type front suspension to improve steering and maintenance
- 0.8 module diff gear to improve efficiency
- Ball type suspension with variable position change of suspension
- Large oil filled shock absorbers front and rear
- Improved driving stability by using long suspension and low center of gravity
- Simple suspension with hinge pins without the use of e-rings
- Front sponge bumper for damage control in crashes
- Includes 3 types of main gears to change gear ratios
- and more...
Technical data:
Length without body: 378.6 mm
Width: 190 mm
Wheel base: 261.5 mm
Front caster: 7 degrees
Gear ratio: 7.992:1
Weight: 1480 g
The new nitro version is as it's electric brother a 4WD shaft type RTR 1:10 GP Touring Car, and will have the following engine specs:
- Exhaust type: side exhaust
- Plug: Normal
- Crankshaft: SG shaft
- Carburetor:Slide type
- Recoil starter type
- Engine size: 12~15
小豪 元老 Fans 发消息
发表于 05-6-10 12:16:00 |显示全部楼层 来自: 中国香港
要內裡的圖哦
強烈關注中.............
[此贴子已经被作者于2005-6-10 12:16:39编辑过]
中意 论坛元老 发消息
发表于 05-6-10 08:26:00 |显示全部楼层 来自: 中国浙江金华
多来点图嘛 ,太少了哦
