感谢 flashyami 提供网址,但那个站常访问不了,于是把图片和文字转载(from palmislife.com) 2005年12月1日全球同步發售 From Japan factory Mini-Z AWD series Item#: 30560B Mini-Z AWD MA-010 Chassis set Brand-new All Wheel Drive (4WD) Mini-Z chassis!!! High efficiency Center Shaft Drive that communicates full Motor torque. 中央傳動軸方式 The power from F/R diff Gear will transmit thorough the Center Shaft and Universal Swing Shaft to All wheels. 使用前後差速及前後萬向傳動軸 Due to the minimum width of 65mm chassis, most of MR01 and MR015 bodies are able to fit. 大部份的MR01 and MR015車殼可以使用 12 pcs of different wheel are included to fit to various bodies. 內附12顆(3套)不同的輪框來對應不同的車殼 Easy to change to the M/L size Mini-Z Racer wheel base. 可輕易改變輪距 4 pcs Ball Bearing included. 附4顆培林 F/R Diff Gear included. 使用前後齒輪差速 Able to change the Rear Tow by using option parts. 使用選配附件即可改變後輪束角 4 kinds of Pinion Gear, 3 kinds of Spar Gear (3 kinds per wheel base, total of 6pcs) is included, so able to change the Gear Ratio as you like. 附4種馬達齒及3種主齒可隨意更換齒比 New receiver amplifier unit (High Grade FET), RA12 is included. 使用新的RA12接收電變模組 Wheels – not able to use regular Mini-Z wheels. Use AWD wheels only. 無法使用之前的miniz輪框 = Technical data and Proto-Type pictures = Technical Data scale 1/27.6 Length 127.5 mm (M)/131.5mm (L) Width 65.0~72.0mm Height 43.0mm Wheelbase 90.0mm (M)/94.0mm (L) Track F : 56.5~63.5mm R :56.5~61.0mm Weight Approx. 135g Motor 130 class Gear Ratio (regular)7.2 : 1 / 6.4 : 1 6.0 : 1 / 6.0 : 1 5.7 : 1 / 5.3 : 1 5.0 : 1 / 4.5 : 1 Front Tyres Φ25.0mm Rear Tyres Φ25.0mm Front Tires width 8.5mm Rear Tires width 8.5~11.0mm Batteries AAA X4 Transmitter Sold separately [upload=jpg]picture/offroad/200582513362595613.jpg[/upload] [upload=jpg]picture/offroad/200582513363712875.jpg[/upload] [upload=jpg]picture/offroad/200582513364880463.jpg[/upload] |
以下是引用ilg123在2005-8-24 18:01:33的发言: 拿Xmods与IW比我有发言权! Xmods的质量比IW好得多的多的多了!!!!!!!!! 我折磨了1个月的XMods一点事也没有 |
