You can see the same motor pod on the both side of the car. Yes it''s twin-motored AWD monster. And you can see also the overland servo box on the main chassis. So this steering system has servo saver function. Wheelbase is lengthened 3mm, and the minimum diameter is 1m-. Stacked 4562 2x2 drive 2 stock motors. With its hyper torque of twin-motor and awd efficiency, the monster can climb over obstacles even at the lowest speed. You don''t need to lock the diff, since the car hardly stuck up. The car won''t wheelie because of the front motor so there''s no hopping or popping, but it has very stabilized ability to crawl. Here''s Real Crawling MZM. 最后这个,饭后甜品[em38] [em50] [此贴子已经被作者于2005-8-25 3:04:01编辑过] |
