carbon 超级元老 发消息
发表于 05-10-1 20:41:00 |显示全部楼层 来自: 中国广东深圳
估计不跑场吧?tb02啦。。电变上个330。。TZ马达。。2pl控。。再买个充电器3条电池。。要漂移再弄套水管胎。。够啦~~
花城文化 元老 Fans 发消息
发表于 05-10-1 20:59:00 |显示全部楼层 来自: 中国广东广州
TA05吧,TB02还是差了些。
always* 超级元老 发消息
发表于 05-10-1 21:06:00 |显示全部楼层 来自: 中国江苏苏州
要漂移直接买TT01D好了。2000能飘了,连设备。
carbon 超级元老 发消息
发表于 05-10-1 21:12:00 |显示全部楼层 来自: 中国广东深圳
以下是引用花城文化在2005-10-1 20:59:26的发言:
TA05吧,TB02还是差了些。
轴的保养方便点嘛。。
馄饨皮子 RC 新手 发消息
发表于 05-10-1 21:15:00 |显示全部楼层 来自: 中国上海
好专业,听不懂,有车的具体介绍发?
馄饨皮子 RC 新手 发消息
发表于 05-10-1 21:19:00 |显示全部楼层 来自: 中国上海
还有你们推荐的车的大概价格
carbon 超级元老 发消息
发表于 05-10-1 21:22:00 |显示全部楼层 来自: 中国广东深圳
TT-01D的具体介绍。。转自towerhobbies。。。。。
Based on the user-friendly TT-01, this 4WD chassis features lightweight bathtub
  frame for low center of gravity and optimum balance. Drift spec additions
  include drift tires, special suspension tunings, full ball bearings, sports-
  tuned motor, aluminum motor heat sink, CVA mini shock dampers and short
  springs.
FEATURES: Chassis:           Plastic tub TT-01D design
          Drive:             Four wheel shaft drive
          Motor:             Sport Tuned 540 motor with pre-attached leads
          Full Metal Ball Bearings
          Shocks:            Friction, plastic body
          Gearbox:           Enclosed, front and rear
          Differentials:     Bevel gear
          Transmission:      Single speed
          Tires:             2.6" (65mm) outer diameter Drift Type Tires
          Wheels:            Mult-vent Dish-type, 2"(51mm) outer diameter, gold
          Speed Control:     TEU-101BK Electronic Speed Control
          Bumpers:           Foam front bumper
          Suspension:        Fixed, non-adjustable
          Camber Tie Rods:   Fixed, non-adjustable, 3 part
          Steering Tie Rods: Fixed, non-adjustable
          Steering:          Bell-crank type
          Servo Saver:       included
INCLUDES: Subaru Impreza WRC 2005 rolling chassis w/friction type shocks,
            540 motor, electornic speed control, clear body, tires, foam
            bumper, spoke wheels, 19 tooth pinion gear, 61 tooth spur gear,
            decal sheet and instructions.
        _
REQUIRES: Radio:           2-channel with 2 standard servos
          Radio Batteries: 8 AA size
          Battery:         6 flat pack with standard connector
          Charger:         AC/DC timed or peak for 6-cell battery
          Paint:           Paint for a lexan body
          Misc. Items:     Building and track equipment
SPECS:      VEHICLE-
          Length:       17.4" (441mm)
          Width:         7.3" (185mm)
          Height:        5.7" (145mm)
          Weight:     2.2lbs   (990g) kit only
                      3.3lbs  (1490g) with battery, speed control, motor and
                                       radio equipment
          Wheelbase:    10.1" (257mm)
          Tread: Front-  6.3" (159mm)
                 Rear-   6.2" (157mm) side-to-side at wheel centers
          Gear Ratio:       8.35:1
          Tires, F&R:   Overall Diameter,       2.6" (65mm)
                        Overall Width,            1" (26mm)
                        Inner Bead Diameter,    1.9" (48mm)
            BODY-
          Length:     17.25" (438mm)
          Width:       7.40" (188mm) at rear wheels
                       7.30" (185mm) at front wheels
          Height:          5" (127mm)
carbon 超级元老 发消息
发表于 05-10-1 21:42:00 |显示全部楼层 来自: 中国广东深圳
论价违法,请见PM
pal 超级元老 发消息
发表于 05-10-1 22:17:00 |显示全部楼层 来自: 中国上海
http://www.tamiya.com/english/products/58349subaru_drift/index.htm关于TT01D的
http://www.tamiya.com/english/products/58345ferrarif430/index.htm   关于TA05的
yellow黄 元老 Fans 发消息
发表于 05-10-5 14:21:00 |显示全部楼层 来自: 中国上海
我有全补tb02要发?
