可恶! 我前两个月刚买了一辆xmods还没买到四驱升级件呢! 几天没事情干 上了一下xmods的主页 www.xmodsrc.com 发现xmods出新车了! 从hummer到lan evo8 贵了十美元 车子各方面也有加强! http://www.atomicmods.com/EVO_faq.htm This is a picture of the Tuner Chassis in the short position This is a picture of the Tuner Chassis in the long position. Note where the chassis has been extended. The process of extending it is very simple. All it takes is 4 screws and you''re done. This is the longer version of the Wishbone Chassis. This is the chassis we have named the Wishbone Chassis This version is the Wishbone Short Chassis. Note were the chassis has been shortened. To switch between these 2 chassis you will have to purchase a couple of extra parts. [此贴子已经被作者于2005-10-22 13:34:12编辑过] |
