我来为大家翻译一下以上列出的新款车的新东西: 1. All aluminum parts will be blue or purple from black 所有铝合金部件为紫色或蓝色 2. Front Solid Axle included 前直轴 3. Aluminum Out Drive (for Ball Differential) included 铝合金差速杯 4.Aluminum Servo Mount included 铝合金舵机固定座 5. Updated Upper Bulkhead included 新款上波箱 6. Updated Middle Block R included 新款中央连接座 7. Center Shaft for no one-way included 中直轴(相对于中单向) 8. 16T Center Pulley included (Total two 16T Center Pulley) 16齿中皮带轮(共两个) 9. New 39T Pulley (Narrow Type) included 新款39T皮带轮(窄型) 10.Front Shock Tower 3.5mm 前油压架3.5mm 11.Rear Shock Tower 3.5mm 后油压架3.5mm 12.Updated Main Frame 2.5mm 新款底板2.5mm 13.Aluminum Spring Mount included 铝合金避震弹簧底座 |
Cyclone Hara and Surikarn "There will be 2 new types of cyclone to be released soon: The Hara & Surikarn Edtions! Of course this chassis includes more spec then the orginal cyclone: 1. All aluminum parts will be blue or purple from black 2. Front Solid Axle included 3. Aluminum Out Drive (for Ball Differential) included 4.Aluminum Servo Mount included 5. Updated Upper Bulkhead included 6. Updated Middle Block R included 7. Center Shaft for no one-way included 8. 16T Center Pulley included (Total two 16T Center Pulley) 9. New 39T Pulley (Narrow Type) included 10.Front Shock Tower 3.5mm 11.Rear Shock Tower 3.5mm 12.Updated Main Frame 2.5mm 13.Aluminum Spring Mount included (#31413) Bule" 想对于现款的CYCLONE第2代有很多设计方面的改进和更新 比如CYCLONE致命的弱点 上半部的波箱 |
以下是引用vinnessken在2005-12-12 8:31:58的发言: 拿油漆换车颜色???那请问那还要很多厂家专门给遥控玩家提供硬阳化处理干什么???呵呵 对了咱们这论坛里有没有做这个的 国内要是有做这个的 大家真可以想给自己车换什么颜色就换什么颜色了 |
以下是引用vinnessken在2005-12-12 8:31:58的发言: [em38][em38][em38]是啊,反正坏车不是你出钱,昨天有坏了什么[em27][em27][em27] PS:还是TT01好啊[em38] [此贴子已经被作者于2005-12-12 12:40:09编辑过] |
以下是引用vinnessken在2005-12-12 8:31:58的发言: [em50][em50][em50][em50][em50][em50][em50][em50][em50][em50][em38][em38][em38][em38][em38][em38][em38] |
