V16R 说明书
查看: 2082|回复: 2| [复制链接]
F103 论坛元老 发消息
发表于 05-12-12 13:18:00 |显示全部楼层 来自: 中国广东佛山
   打好了...
1/10 ELECTRONIC SPEED CONTROLLER
Specifications/Features
   Input Voltage :4.8v-8.4v(4-7cells)
   "NO"resistance : 0.00165 ohm
   Impulse current of MOSFET : 125A
   PWM frequency : 2k-4khz
   BEC output voltage : 5.0v(2A)
   Forward/brake/reverse
   Easy setup
Setup and Installation
  Turn off the ESC by using the power switch
  Connect the motor,battery,and receiver as shown in Fig.1
  Switch on the radio
  Move the throttle stick to neutral position
  Switch on the ESC (The motor will move slightly)
  Press "SET" button and hold until the LED lamp flashes
  Radio throttle stick stays at neutral and press the setup button(the LED Lamp will turn off)
  Move the radio throttle stick to full throttle and then press the setup button (the LED lamp will flash)
  Move the radio throttle stick to full brake and then press the setup button (the LED lamp will turn off)
[em38][em38][em38]大错别濑我
nerv 终极 Fans 发消息
发表于 05-12-12 13:46:00 |显示全部楼层 来自: 中国广西梧州
      谢[em50][em50][em49]
小李 该用户已被删除
发表于 05-12-12 15:03:00 |显示全部楼层 来自: 中国广东佛山
