本帖最后由 力动模型 于 12-4-20 10:56 编辑 力动模型--模型遥控器18MZ!!有此控可驰诧RC界。哈哈 商品介绍: 在14MZ的基礎上增加了4個通道,達成了16線性通道+2開關通道共18通道可用,加入了許多新的機能,採用TFT-LCD螢幕降低耗電,內存記憶卡由過去的CF改用SD卡,螢幕底下同樣保留4個按鈕加上滾輪的搭配,外型硬體上的配置幾乎與14MZ相差無幾,就是造型做了改變。硬要說很大的變動,那應該就是加入了一個攝像頭在背後,可以拍攝你的愛機作為螢幕的表示圖案。 另一個較大的變動,就是18MZ採用專用的FASST-est(extended system telemetry),簡單的說18MZ也支援雙向遙測系統了,所以在接收機的使用上,除了專屬的FASST-est接收機,也可以向下相容所有Futaba 2.4G接收機。接收機方面,則是搭配了R7008SB,從型號跟尺寸上看來,應該沒有實體上的18個插頭,而是利用S.BUS來實現,而R7008SB也如同當初所看到的,是使用S.BUS2系統,這個專位T18MZ所設計的接收具備了雙向遙測功能,包括電壓、接收電壓、多組溫度監控、轉速、氣壓高度表、GPS等功能(配件另購) 還有一點是,這次使用的電池是3500mAh,而且尺寸與接線方式看起來很”合理”,過去要準備一堆攝影機電池…喔不,是準備一堆備用電池的日子應該可以獲得改善。 About the 18MZ System It’s the first true 18-channel Futaba radio system ever. It comes with an R7000SB receiver, as well as transmitter and receiver batteries. The R7008SB is a high-voltage design that lets you use as many — or as few — channels as you want. You can operate on up to 8 channelsusing the 8 standard PWM inputs. Servo options are wide open, ranging from simple analog to S.Bus and new S.Bus2 servos. You have access to up to 18 channels(16 proportional + 2 digital) through the 18MZ’s two S.Bus2 ports. That means simpler, more foolproof setup and full support for S.Bus and S.Bus2 servos. It features a SD Card slot.Slide a card in the slot, and you have ample (and adjustable) capacity for updates, model memory and more. It includes versatile “internal memory”. It’s not just for model/setup data; it can also be used for sound and picture files. That’s especially nice, since the 18MZ has… Abuilt-in0.3M megapixel camera. No need for a digital camera or even a flip phone. Just point the 18MZ, click and you have a foolproof picture ID of your model in seconds. It includes a 6” touch screen with 640x240 resolution. Big, brilliant and backlit for easy viewing anywhere, it provides sparkling clarity on remarkably little power. Gentle finger pressure is all that’s needed for fast, easy navigation and programming. You can download software updates online. This is a standard feature for Futaba computer systems, and easily one of the most popular customer “perks.” It’s a fast and easy way to keep your system “current”. A 7.4V, 3500mAh LiPo transmitter battery is standard equipment. It features a built-in U.S.B. Port. You can use it to connect a memory stick or connect it to a keyboard or mouse or use it to download telemetry data to your PC or laptop for storage and reference. It includes a Serial Interface, too. Futaba already offers a stand-alone serial interface (the CIU-2) for programming the travel, endpoint and other functions of S.Bus and S.Bus2 servos. This built-in (and the free download) lets you do the same with the 18MZ. Stick angle adjusts quickly and easily. First introduced on the 14MZ, the adjustable gimbal angles feature has proven so popular that it was included on the 18MZ, as well. It’s more than a comfort/convenience feature; it allows you to customize your control setup for greater ease and precision. 免费内容: http://player.youku.com/player.php/sid/XMzUxODg4NzIw/v.swf 联系方式: 公司地址:广东省佛山市禅城区深华路雅居乐8号2区首层P48号商铺 公司电话:0757-83070287 公司官网:http://www.ldmx88.com 公司淘宝:联系人:力动模型--啊兵 QQ:2473254413 阿里旺旺:新动力模型:阿兵力动模型-- [ 本帖最后由 力动啊兵 于 2012-2-29 17:47 编辑 ] 附件 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
本帖最后由 力动模型 于 12-4-20 10:57 编辑 在2011年日本静冈展上,Futaba终于公开发表了其下一代旗航级机种——18MZ。所展出的18MZ尚属参考版本,与正式上市的机种或有差别,但大体机能应该与最终上市的版本相差无几。继Futaba的14MZ(发布日距今已6年)神机之后,18MZ或许将要创造新的神话,它拥有令人惊叹的18个通道,尽管你有可能一辈子也无法使用完这些通道,也或许当你一边飞行一边使用10多种功能的时候会感到手忙脚乱,更也许……这些猜测都是多余。18MZ采用内置2.4G高频头模组,采用FASSTest技术,和上一代机种14MZ一样采用了大尺寸的彩色触摸式液晶屏(是否会改为更加好用的电容式触摸屏暂时不得而知,但可知的是,如果不改则很可能招来客户意见),屏幕分辨率为640 x 240。18MZ内置了一个100万像素的摄像头,从此以后你可以把模型飞机的实物拍摄下来作为图标了。18MZ还很有可能内置遥测功能(Telemetry),能将飞行数据直接显示在遥控器液晶屏上。18MZ的上市时间预计在2011年9月,预计售价会接近3万元人民币。 ![]() ![]() 2012-2-29 14:25 ![]() ![]() 2012-2-29 14:25 ![]() ![]() 2012-2-29 14:25 ![]() |
要如何用好18个通道呢? 这里有一个参考意见: 1 - Throttle (油门) 2- Aileron (副翼) 3 - Rudder (方向) 4 - Elevator (升降) 5 - Landing Gear (收放轮) 6 - Landing Gear brakes (机轮刹车) 7 - Air Brakes (空气刹车) 8 - Lights (灯光) 9 - Engine Starter (引擎启动) 10 - Flaps (襟翼) 11 - Slats (??) 12 - Rev thrust (??) 13 - Canards (for some planes) ?? 14 - Bomb Drop (投弹) 15 - Pyrotechnics(small explosives, rockets) ?? 16 - Smoke (拉烟) 17 - Telemetry (遥测) 18 - FPV camera Control (第一视角控制) |
