dairy 金牌 Fans 发消息
发表于 06-2-4 01:01:28 |显示全部楼层 来自: 中国广东广州
Robitronic Avid Prototype
dairy 金牌 Fans 发消息
发表于 06-2-4 01:01:43 |显示全部楼层 来自: 中国广东广州
dairy 金牌 Fans 发消息
发表于 06-2-4 01:02:13 |显示全部楼层 来自: 中国广东广州
Hot Bodies
dairy 金牌 Fans 发消息
发表于 06-2-4 01:02:49 |显示全部楼层 来自: 中国广东广州
Tamiya F103GT
TRF Special Damper - F103GT
Add these oil dampers to your F103GT Chassis for even better performance. Low friction fluorine coating of cylinder, together with titanium coated piston, secures smooth damper movement. Adjustable type spring retainer allows for fine tuning of spring pressure.
*Compatible chassis: F103 and C Car chassis
F103GT Aluminum Motor Mount - Height Adjustable/Blue
Blue anodized aluminum mount features durable construction capable of maintaining precise center distance, as well as improved heat dissipation. Perfect for use with Item 53900 04 Module Spur Gear or during long-distance races.
*Compatible chassis: F103RX, F103LM-TRF Special Chassis, F103GT Chassis
*In order to use with F103, F103L, F103LM, F103RS Chassis, Item 53257 Height Adjustable Gear Case must be used.
This 3.0mm thick carbon lower deck offers improved durability and 2.3g weight savings over the standard FRP deck. Perfect for use with Item 53394 F103LM Carbon Upper Deck.
*Compatible chassis: F103GT Chassis (may also be used with F103, F103L, F103LM Chassis that has been converted into an F103GT)
[ 本帖最后由 dairy 于 2006-2-4 01:50 编辑 ]
dairy 金牌 Fans 发消息
发表于 06-2-4 01:04:28 |显示全部楼层 来自: 中国广东广州
New Kyosho 1/10 Touring for the Worlds
Kyosho也上电车了..快看看!!!!
dairy 金牌 Fans 发消息
发表于 06-2-4 01:04:40 |显示全部楼层 来自: 中国广东广州
dairy 金牌 Fans 发消息
发表于 06-2-4 01:04:49 |显示全部楼层 来自: 中国广东广州
唐乾钧 超级元老 发消息
发表于 06-2-4 01:39:16 |显示全部楼层 来自: 美国
看了下..感觉kyosho的车象TA05的op版..然后就是第一辆车.....感觉单薄了点...
dairy 金牌 Fans 发消息
发表于 06-2-4 01:45:20 |显示全部楼层 来自: 中国广东广州
TRF415MSX Lower Deck
Turn your TRF415MSX into an Ultimate High-end Touring Car!
This conversion kit allows you to mount a standard 7.2V racing pack battery onto the TRF415MSX chassis, turning your machine into a pure racing-ready high-end touring car. Parts have been designed with an eye towards easy maintenance, and optimum balance.
About the Model
All new lower deck (2.5mm carbon), carbon upper deck, rear bulkhead and aluminum center post
Includes battery plate designed for use with 7.2V racing pack battery
Use this blue aluminum mount to increase setting choices on TRF415 or TA05 chassis.
[ 本帖最后由 dairy 于 2006-2-4 01:52 编辑 ]
dairy 金牌 Fans 发消息
发表于 06-2-4 01:46:56 |显示全部楼层 来自: 中国广东广州
TA05 LW Carbon Lower Deck
Incorporates lightweight and durable carbon fibers to improve chassis rigidity, improving handling response and traction.
