The brandnew Robitronic Protos RTR 1/8th scale buggy is designed for maximum performance on the track, built for beginners and experienced drivers. The Axial 4.6 big block engine delivers incredible performance and is easy to adjust. The Protos RTR needs no long wrenching. It´s factory assembled and have a perfect basic set-up to hit the track. Intelligent design of the chassis makes this buggy easy to handle and ultra durable. The very low point of gravity, the sealed gearings, hardend gears ultra durable plastic material makes the Protos fit for each area and makes sure a long life time under hardest conditions. Protos – the new class in 1/8th scale off road. Features • 4WD Shaft-Drive System • Powerful Axial .28 Pull Start Engine • Adjustable Suspension System • Fully Sealed Bearings • Red anodized 3mm Aluminum Chassis • Red anodized Aluminum Upper Deck • Composite Shocks • Composite Shock Towers • Composite Suspension Arms • Composite Exhaust Pipe • Sealed Receiver Box • Sealed Center Gear Box • Floating front and rear differentials • Two Stage Air Filter • Exclusive Ultra Low Diff design for lower center of gravity • 4 Bevel Gear Diffs • Unique Braking System with Dual Brake Disk • Rubber dampened hinge pin pivot points for better bump absorbsion and increased durability • Thick composite chassis braces front & rear • Hi-Performance Radio System • Lay down Steering Servo • Pre-Glued Tires • 10 Spoke Wheels • Low profile buggy body • Fully printed, decaled and trimmed body Also include additional features: • Fuel Bottle • Glow Plug Igniter • Glow Plug Wrench • Cross Wrench All you need is fuel and AA batteries and you are ready to go. Specification Length: 494mm Width: 305mm Wheelbase: 329mm Height: 190mm Tire Diameter: 120mm Weight: 2800g Fuel Tank capacity: 125ccm Final Drive Ratio: 3.5:1 Pinion/Spur Ratio: 3.1:1 |
