Team Losi celebrates their 25th year of offering racers unmatched race proven designs and features with the release of the 揦XX-CR?2WD off-road racing buggy. The CR designation is a throw back to the Losi heritage offering 揅ompetition Ready?kits incorporating innovative thinking, cutting edge design and unmatched material technology. The Team Losi engineering and development team have redesigned and revised a number of key elements for the XXX-CR to take full advantage of the latest generation of hi-performance motors, batteries, and tires. The CR also benefits from Team Losi抯 exclusive new 揈A3?composite material for more durability than any buggy you've ever driven. The unique combination of design, hi-tech components and materials lets the XXX-CR produce incredible acceleration and stability through the roughest track sections and tightest turns. The wide range of adjustability and predictable handling makes the XXX-CR even easier to drive fast. New VLA rear suspension arms with revised geometry Revised rear shock tower/bulkhead with more tuning options New symmetrical VLS type rear hubs with vertical ball studs New steering rack configuration for greater handling predictability New molded gear cover and plug for added protection Redesigned long-life differential requiring less maintenance revised front shock tower with greater tuning options New "HD" heavy-duty ball studs with a hex in the head New battery strap with extra holding capacity for the latest cells New tunable aero package - body, front and dual element rear wing Revised XXX transmission with 2.43 final drive ratio New beefier Titanium turnbuckles and heavy duty grey ball cups In addition to these new features look for Ti-Nitride shock shafts and hinge pins, hard anodized threaded shock bodies, suspension balls and top shaft, machined 7075 aluminum motor plate, ball bearing steering and other components simply not offered by any other manufacture. The result is a feature packed competition kit that is unmatched for quality, content and performance. Look for the XXX-CR to be showing up at racetracks and hobby shops worldwide this summer. LOSA0032 XXX-CR 2wd Competition Buggy Kit estimated street price $224.99 |
