lg1043 论坛元老 发消息
发表于 06-4-24 10:18:31 |显示全部楼层 来自: 中国广东深圳
我试了一下,发现弯管会压到中皮带,(因为sss中皮带的位置比rrr的要更靠外一点),不知道有没有办法解决?
菜刀 终极 Fans 发消息
发表于 06-4-24 10:36:28 |显示全部楼层 来自: 中国上海
因为S3的中轴要考虑到绕过手拉启动的位置,所以中皮带比较靠外侧,普通的后排排气管肯定不能用。除非直接换R的2楼板和主、中轴吧。
Allan0628 超级元老 发消息
发表于 06-4-24 11:07:00 |显示全部楼层 来自: 中国北京
原帖由 菜刀 于 2006-4-24 10:36 发表
呵呵,连底板都要换……还得换中皮带座、后波箱上盖板等等……
demon 超级元老 发消息
发表于 06-4-24 17:40:55 |显示全部楼层 来自: 中国上海
自己弄个变态的弯管应该可以,呵呵
lg1043 论坛元老 发消息
发表于 06-4-24 22:36:53 |显示全部楼层 来自: 中国广东深圳
原帖由 demon 于 2006-4-24 17:40 发表
自己弄个变态的弯管应该可以,呵呵
实在不行,也只能这样了,就是不知道好不好操作?:em21:
BMW500 终极 Fans 发消息
发表于 06-4-26 00:11:15 |显示全部楼层 来自: 中国湖北黄石
不能
chrishkyung1010 RC 新手 发消息
发表于 06-4-26 13:48:01 |显示全部楼层 来自: 中国香港
I have Vone RRR and Vone 3S.  The one say "no, it cant" ? Do you have Vone 3S.  I surely tell you that 3S can be equipped with rear exhaust engine.   The following options is suggested for lg1043
1) Low profile engine mount
    i) low profile engine mount of 3R shall be purchased
    ii) buy the 3R push clutch or modify your existing flywheel to reduce the diameter
    iii) dont buy in-line pipe set....you shall buy the old style pipe set...e.g. use silicone rubber to connect pipe and manifold..
    iv) the manifold you choosed must have wider span from the engine exhaust....only few manifolds available in market are suitable to 3S.  Personally, I use SH manifold...please search
2) Standard Engine Mount
    i) Buy standard engine mount
    iii) the manifold you choosed must have wider span from the engine exhaust....only few manifolds available in market are suitable to 3S.  Personally, I use SH manifold...please search
Hope the above information could help you.. BTW, please be reminded that if you dont know the real answer, please dont make any faking answer to show off yourself....
lg1043 论坛元老 发消息
发表于 06-4-26 23:02:22 |显示全部楼层 来自: 中国广东深圳
谢谢,i have  Low profile engine mount and the 3R push clutch ,a good guy talk to me that  the new MAX's manifold maybe are suitable to 3S,tomorrow will  go search and try the  SH and MAX manifold,   :handshake thanks at all
