nivea 金牌 Fans 发消息
发表于 06-5-1 12:36:27 |显示全部楼层 来自: 英国
Serious Down Force for the LST/2
From Baja to your back yard, everyone knows down force helps you put the power to the ground. Now Team Losi helps you put more of that awesome power available in your LST and LST2 to the ground with their new LST rear wing kit. The LOSB8050 wing kit includes simple bolt-on struts engineered to be sturdy yet light, all hardware, and a tough injection molded wing. The wing is nothing short of a work of aerodynamic art. The multi-element design produces high down force with a minimum of drag, much like an Indy or Formula One car. The added performance is remarkable but the look is sensational. The addition of the rearward sloping wing protruding up from the back of the bed makes the LST and LST2 look like it’s ready to fly. In addition to the complete kit both the struts and the wing are available separately. Look for these and all Genuine Team Losi replacement and performance parts at hobby shops and racetracks worldwide.
LOSB8150 Rear Wing Kit LST/2 $14.99
LOSB8151 Rear Wing Only LST/2 9.00
LOSB2501 Rear Wing Struts LST/2 9.00
jingrong 超级元老 发消息
发表于 06-5-2 23:31:05 |显示全部楼层 来自: 中国上海
呵呵比revo 的尾巴便宜多了啊
