1/16 Chaos Nitro 4WD RTR Buggy Key Features Four-wheel independent suspension system Oil-filled, coil-over shocks 4WD drivetrain with 3 gear differentials Heavy-duty countersunk aluminum chassis Full ball bearings Micro-pin tires mounted & glued on dish wheels Composite brake disc 40cc fuel tank Sealed radio box Low-profile air cleaner 3-shoe centrifugal clutch Adjustable throttle/brake linkage system .05 cu in racing engine with recoil starter Oversized, machined heat-sink head Aluminum tuned exhaust system High-torque mini servos 27MHZ AM digital proportional radio system with steering ATV Factory-finished body and a molded nylon high-downforce rear wing Overview Take a little disorder with you wherever you go, thanks to the Chaos from Sportwerks. Bringing all of the fire-breathing nitro power, 4WD performance and dirt-throwing excitement of 1/8 scale buggy racing to the mini world, the Chaos lets you fuel up and fire up nearly anywhere thanks to its size. A .05 cubic inch racing engine and tuned exhaust generate intense power in a small package, all channeled through 3 gear differentials and a tough 4WD setup. Ball bearings throughout reduce friction for increased durability. Oil-filled shocks and an independent suspension absorb nearly any terrain you can find, while multi-purpose tires on racing dish wheels provide tons of traction. Best of all, the Chaos comes pre-painted and ready-to-run so you can fill the tank and hit the ground running right from the box. The Chaos from Sportwerks. No other nitro mini even comes close. Specs Type: 4WD Nitro Buggy RTR Scale: 1/16 Length: 10.2" Width: 7.08" Wheelbase: 6.7" Chassis: Aluminum Suspension: 4-wheel independent Drive Train: Center shaft drive w/3 differentials Tire Type: Micro-pin all terrain Motor or Engine: .05 cu in with recoil starter Radio: Sportwerks 2 channel digital proportional 27MHZ AM Servos: Micro x 2 Shock Type: Oil-filled, coil over type Body: Factory-finished buggy type Ball Bearings: Complete Fuel Tank Capacity: 1.3 oz (40cc) Needed to Complete 8 AA alkaline batteries for TX 4 AAA alkaline batteries for RX Glow igniter Fuel bottle Fuel (30% Blue Thunder recommended) |
