AxialRacing新轮胎
查看: 1986|回复: 7| [复制链接]
council 长老 Fans 发消息
发表于 06-5-16 05:58:09 |显示全部楼层 来自: 英国
AX12000
The Dirt Devil tire was created with the soft sloppy terrain in mind. The paddle like crescent shaped blocks offer good ‘dig’ and clear the way for the large square blocks to grip the terrain. While the large open spacing allows for excellent clean out and resists packing of mud to the tire. These are intended to be the ultimate bashing and soft terrain racing tire.
Internal ribbing helps prevent sidewall flex and special stepped inner foam helps keep the tire shape consistent on the track.
• Paddle like crescent shapes for increased traction in the soft stuff
• Best suited for soft sloppy conditions
• Internal ribbing to reduce sidewall flex
• Stepped inner foam keeps the shape of the tire consistent during running
• Outside Diameter – 149mm
• Inside Diameter – 80mm
• Width – 75mm
council 长老 Fans 发消息
发表于 06-5-16 05:59:30 |显示全部楼层 来自: 英国
AX12001
Terra-izer MT tire
Get ready to tear up the track with the new Terra-izer tires from Axial. The Terra-izer was designed using successful professional motocross tire tread concepts and successfully adapting them to the R/C Monster truck environment. The block pattern in the center of the tire is similar to what you might find on a pro racers motocross bike, while the side blocks have been optimized to provide constant traction even when the vehicle is at extreme lean angles and still allow forward bite to the racing surface. All this adds up to improved traction on medium packed track conditions.
• Based on professional motocross tread concepts
• Angled side blocks for increased traction in turns
• Best suited for medium packed track conditions
• Outside Diameter – 147mm
• Width – 75mm
大脚fans 论坛元老 发消息
发表于 06-5-16 07:28:30 |显示全部楼层 来自: 中国江苏连云港
轮轱挺漂亮的
三藏 超级元老 发消息
发表于 06-5-16 09:36:14 |显示全部楼层 来自: 中国北京
轮胎和轮毂的价格不菲啊!当静态很绚啊!
心影 论坛元老 发消息
发表于 06-5-16 10:17:28 |显示全部楼层 来自: 中国广东佛山
轮毂喜欢~~
BI 论坛元老 发消息
发表于 06-5-16 10:29:32 |显示全部楼层 来自: 中国广东广州
第一靓啊~!
野風 终极 Fans 发消息
发表于 06-5-16 14:50:58 |显示全部楼层 来自: 中国广东中山
都好看
527824 论坛元老 发消息
发表于 06-5-17 02:21:51 |显示全部楼层 来自: 中国辽宁辽阳
轮毂喜欢~~
